JSONapi sort product
Indra
Post by Indra » 30 May 2019, 08:36
Hi, I ran into problem when I try to sort with 2 criteria as documentation said using
sort: '-product.label,product.id'
if 1 criteria, its succesfully return sorted data, but 2 criteria will print error
"title": "Invalid name \"product.label,-product.id\""
Any idea?
Re: JSONapi sort product
Post by aimeos » 02 Jun 2019, 15:53
Thanks for reporting, this is a bug due to the rewritten frontend controller in version 2019.04. It's now fixed in dev-master and 2019.04.
