Getting errorException "Too many connections"
Harpal Singh
Post by Harpal Singh » 14 Jun 2019, 05:50
I am getting an exception randomly like ErrorException (E_ERROR)
An exception occurred in driver: SQLSTATE[HY000] [1040] Too many connections
in my 'frontpanel_nav.blade.php' file.
This happens randomly on any page of the site. Sometimes the same page runs smoothly as usual but sometimes this exception appears on the same page.
Harpal Singh
Re: Getting errorException "Too many connections"
Post by aimeos » 14 Jun 2019, 09:03
If you have overwritten any classes, please make sure you have as release() for each acquire(), even on exceptions.
Harpal Singh
Post by Harpal Singh » 17 Jun 2019, 11:04
I havn't extended any class but using calling some header functions in my files like :
/** To Get language and Currency **/
function getLocaleCurrency()
    $arr = [];
    $context = app( '\Aimeos\Shop\Base\Context')->get();
    $locale = $context->getLocale();
    $arr['language'] = $locale->getLanguageId();
    $arr['currency'] = $locale->getCurrencyId();
    $arr['site'] = $locale->getSite();
    return $arr;
function getCategoryByProductId($id) {
    $context = app('\Aimeos\Shop\Base\Context')->get();
    /** @var \Aimeos\MShop\Catalog\Manager\Standard $manager */
    $manager = \Aimeos\MShop\Catalog\Manager\Factory::createManager( $context );
    $search = $manager->createSearch( true );
    $expr = array(
        $search->compare('==', 'catalog.lists.refid', $id),
        $search->compare('==', 'catalog.lists.domain', 'product'),
    $search->setConditions($search->combine('&&', $expr));
    $categoryItems = $manager->searchItems($search);
     return $categoryItems;
etc.
and I think there is problem in these functions.
How can I release connection? I mean What is syntax for it.
Aimeos\MW\DB\Exception thrown with message "An exception occurred in driver: SQLSTATE[HY000] [1040] Too many connections"
Stacktrace:
#69 Aimeos\MW\DB\Exception in /vendor/aimeos/aimeos-core/lib/mwlib/src/MW/DB/Manager/DBAL.php:114
#68 Aimeos\MW\DB\Manager\DBAL:acquire in /vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Common/Manager/Base.php:83
#67 Aimeos\MShop\Common\Manager\Base:createSearch in /vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Catalog/Manager/Standard.php:269
#66 Aimeos\MShop\Catalog\Manager\Standard:createSearch in /vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Common/Manager/Base.php:302
#65 Aimeos\MShop\Common\Manager\Base:createSearchBase in /vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Catalog/Manager/Standard.php:266
#64 Aimeos\MShop\Catalog\Manager\Standard:createSearch in /vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Common/Manager/Decorator/Base.php:88
#63 Aimeos\MShop\Common\Manager\Decorator\Base:createSearch in /app/Helper/helper.php:2120
#62 getCategoryByProductId in /ext/azx/client/html/templates/catalog/detail/body-standard.php:207
#61 include in /vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php:251
#60 Aimeos\MW\View\Standard:includeFile in /vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php:233
#59 Aimeos\MW\View\Standard:render in /ext/ai-client-html/client/html/src/Client/Html/Catalog/Detail/Standard.php:192
#58 Aimeos\Client\Html\Catalog\Detail\Standard:getBody in /vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Base/Page.php:91
#57 Aimeos\Shop\Base\Page:getSections in /vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Controller/CatalogController.php:46
#56 Aimeos\Shop\Controller\CatalogController:detailAction in /vendor/laravel/framework/src/Illuminate/Routing/Controller.php:54
#55 call_user_func_array in /vendor/laravel/framework/src/Illuminate/Routing/Controller.php:54
#54 Illuminate\Routing\Controller:callAction in /vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php:45
#53 Illuminate\Routing\ControllerDispatcher:dispatch in /vendor/laravel/framework/src/Illuminate/Routing/Route.php:212
#52 Illuminate\Routing\Route:runController in /vendor/laravel/framework/src/Illuminate/Routing/Route.php:169
#51 Illuminate\Routing\Route:run in /vendor/laravel/framework/src/Illuminate/Routing/Router.php:665
#50 Illuminate\Routing\Router:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:30
#49 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php:41
#48 Illuminate\Routing\Middleware\SubstituteBindings:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#47 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#46 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php:68
#45 Illuminate\Foundation\Http\Middleware\VerifyCsrfToken:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#44 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#43 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php:49
#42 Illuminate\View\Middleware\ShareErrorsFromSession:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#41 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#40 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php:63
#39 Illuminate\Session\Middleware\StartSession:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#38 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#37 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php:37
#36 Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#35 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#34 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php:66
#33 Illuminate\Cookie\Middleware\EncryptCookies:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#32 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#31 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:104
#30 Illuminate\Pipeline\Pipeline:then in /vendor/laravel/framework/src/Illuminate/Routing/Router.php:667
#29 Illuminate\Routing\Router:runRouteWithinStack in /vendor/laravel/framework/src/Illuminate/Routing/Router.php:642
#28 Illuminate\Routing\Router:runRoute in /vendor/laravel/framework/src/Illuminate/Routing/Router.php:608
#27 Illuminate\Routing\Router:dispatchToRoute in /vendor/laravel/framework/src/Illuminate/Routing/Router.php:597
#26 Illuminate\Routing\Router:dispatch in /vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php:176
#25 Illuminate\Foundation\Http\Kernel:Illuminate\Foundation\Http\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:30
#24 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/spatie/laravel-cookie-consent/src/CookieConsentMiddleware.php:12
#23 Spatie\CookieConsent\CookieConsentMiddleware:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#22 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#21 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /app/Http/Middleware/SetLocale.php:99
#20 App\Http\Middleware\SetLocale:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#19 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#18 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/fideloper/proxy/src/TrustProxies.php:57
#17 Fideloper\Proxy\TrustProxies:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#16 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#15 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php:31
#14 Illuminate\Foundation\Http\Middleware\TransformsRequest:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#13 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#12 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php:31
#11 Illuminate\Foundation\Http\Middleware\TransformsRequest:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#10 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#9 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php:27
#8 Illuminate\Foundation\Http\Middleware\ValidatePostSize:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#7 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#6 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php:62
#5 Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode:handle in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:151
#4 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in /vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php:53
#3 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in /vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:104
#2 Illuminate\Pipeline\Pipeline:then in /vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php:151
#1 Illuminate\Foundation\Http\Kernel:sendRequestThroughRouter in /vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php:116
#0 Illuminate\Foundation\Http\Kernel:handle in /public/index.php:66
Harpal Singh
Post by aimeos » 18 Jun 2019, 07:34
Is this a dev or production environment?
The Aimeos methods are usually save and use acquire() and release() symetrically. They also case about exceptions. You can check if you add a debug statement to the acquire() and release() methods of \Aimeos\MW\DB\Manager\DBAL (https://github.com/aimeos/aimeos-core/b ... r/DBAL.php) and compare acquire/release pairs.
Harpal Singh
Post by Harpal Singh » 20 Jun 2019, 10:44
I have checked my .env and APP_ENV = local and APP_DEBUG=true.
Should I change APP_ENV to production and APP_DEBUG=false to fix the problem?
Harpal Singh
Post by aimeos » 20 Jun 2019, 20:04
No, reconfiguring APP_ENV won't help. You should add an error_log() output to acquire() and release() to see if they are symetrically called.
Harpal Singh
Post by Harpal Singh » 26 Jun 2019, 11:11
aimeos wrote:No, reconfiguring APP_ENV won't help. You should add an error_log() output to acquire() and release() to see if they are symmetrically called.
Where should I use error_log() and how, can you please brief?
Harpal Singh
Post by Harpal Singh » 27 Jun 2019, 05:52
I am stuck on this error. Now, this is happening very frequently. Unable to debug the issue where it is.
What do you suggest how to debug the problem and what can be a solution?
Harpal Singh
Post by aimeos » 27 Jun 2019, 09:16
You problem might be somewhere else like stated in the other post
