delivery date
yong
delivery date
Post by yong » 03 Jul 2019, 13:05
Hi, i've 2 issues :
1- I've set the deliverystatus of an order to delivered but the deliverydate havn't change (it's always equal to null), how can i change it ?
2- please what is the signification of code for paymentstatus and deliverystatus ?
Re: delivery date
Post by aimeos » 03 Jul 2019, 16:06
yong wrote: 03 Jul 2019, 13:05 1- I've set the deliverystatus of an order to delivered but the deliverydate havn't change (it's always equal to null), how can i change it ?
In the order detail view of the admin interface, there's the "Invoice" tab with a list of invoices. If you click on the icon on the top right of the list, you can add "Delivery" to the list of available columns. Press the icon with the search glass afterwards.
yong wrote: 03 Jul 2019, 13:05 2- please what is the signification of code for paymentstatus and deliverystatus ?
Here you can find explanations what that status values should be used for:
https://github.com/aimeos/aimeos-core/b ... p#L44-L153
