How to add own action to admin ?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 16 Jul 2019, 17:10
Laravel Framework 5.8.26
aimeos-laravel 2019.04
As I see \Aimeos\Shop\Controller\JqadmController has several actions like 'get', 'search' and other. I need implement my own action 'download'. And this action must send file to browser. In my \Aimeos\Admin\JQAdm\Documents\Standard class I try to do it under export action:
return response()->download($file);
But it doesn't work, file is not downloaded. Browser just show me html code. I think it is because each action of \Aimeos\Shop\Controller\JqadmController does the following:
return $this->getHtml( $html );
How can I avoid it ?
Re: How to add own action to admin ?
Post by aimeos » 17 Jul 2019, 08:54
You should create your own action that handles the output for downloads correctly, Then, you can configure the named route you've defined for your action in the Aimeos config: https://github.com/aimeos/aimeos-larave ... lt.php#L70
In your JQAdm class, you need to use
$this->config( 'admin/jqadm/url/download/target' )
to retrieve the named route and pass it to the "$this->url()" method to generate the required URL.
We would love to get your changes into Aimeos. Can you create a pull request on GitHub for your changes?
