Catalog / List / Concerns about selections
Re: Catalog / List / Concerns about selections
Post by aimeos » 18 Jul 2019, 17:07
It works the way you described and there's no other because only categorized products can be bought. That's due to the "Category" decorator for the basket frontend controller which enforces that:
https://github.com/aimeos/ai-controller ... tegory.php
I wouldn't remove the decorator because otherwise, rebate products could be added to the basket as well if someone knows their ID.
There was an index problem for the "add to basket" functionality in the list view. Can you try ai-client-html 2019.07.x-dev?
