Set up front-end shop without '/public' in url
MikaelNazarenko
Expert
Post by MikaelNazarenko » 24 Jul 2019, 11:54
Hi guys!
Laravel Framework 5.8.26
aimeos-laravel 2019.07
I am trying to set up front-end shop.
/var/www/schmuck/resources/views/app.blade.php :
<!DOCTYPE html>
<html lang="en" class="no-js">
<head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1">
    @yield('aimeos_header')
    <title>Aimeos on Laravel</title>
    <link type="text/css" rel="stylesheet" href='https://fonts.googleapis.com/css?family=Roboto:400,300'>
    <link type="text/css" rel="stylesheet" href="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css">
    @yield('aimeos_styles')
</head>
<body>
<nav class="navbar navbar-default">
    <div class="container-fluid">
        <div class="navbar-header">
            <button type="button" class="navbar-toggle collapsed" data-toggle="collapse" data-target="#bs-example-navbar-collapse-1">
                <span class="sr-only">Toggle Navigation</span>
                <span class="icon-bar"></span>
            </button>
            <a class="navbar-brand" href="#">Laravel</a>
        </div>
        <div class="collapse navbar-collapse" id="bs-example-navbar-collapse-1">
            <ul class="nav navbar-nav">
                <li><a href="/">Home</a></li>
            </ul>
            <div class="nav navbar-nav navbar-right">
                @yield('aimeos_head')
            </div>
        </div>
    </div>
</nav>
<div class="col-xs-12">
    @yield('aimeos_nav')
    @yield('aimeos_stage')
    @yield('aimeos_body')
    @yield('aimeos_aside')
    @yield('content')
</div>
<!-- Scripts -->
<script type="text/javascript" src="https://code.jquery.com/jquery-3.1.1.min.js"></script>
<script type="text/javascript" src="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/js/bootstrap.min.js"></script>
@yield('aimeos_scripts')
</body>
</html>
/var/www/schmuck/routes/web.php :
Route::get('/', function () {
    return view('app');
But the /shop page looks like https://prnt.sc/ojdqis
It is because I removed 'public' from url (rename server to index and customize htaccess)
/var/www/schmuck/.htaccess :
Options -MultiViews -Indexes
RewriteEngine On
# Handle Authorization Header
RewriteCond %{HTTP:Authorization} .
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
# Redirect Trailing Slashes If Not A Folder...
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_URI} (.+)/$
RewriteRule ^ %1 [L,R=301]
# Handle Front Controller...
RewriteCond %{REQUEST_URI} !(\.css|\.js|\.png|\.jpg|\.gif|robots\.txt)$ [NC]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteRule ^ index.php [L]
RewriteCond %{REQUEST_URI} !^/public/
RewriteRule ^(css|js|images)/(.*)$ public/$1/$2 [L,NC]
As I see js scripts and other resources are not loaded, it tries to get it by http://schmuck/packages/aimeos/shop/the ... aimeos.css
What should I do ? Edit htaccess ?
I hope maybe I can set correct path somewhere in Aimeos config ?
Re: Set up front-end shop without '/public' in url
Post by aimeos » 24 Jul 2019, 19:38
Your Larave ./public/ directory must be the document root of your domain - esp. for security reasons!
MikaelNazarenko
Expert
Post by MikaelNazarenko » 24 Jul 2019, 22:01
I have changed it safety. A lot of people remove that /public from url because it is ugly.
IT is worry that nobody can tell me how to solve the problem ?
Post by aimeos » 25 Jul 2019, 06:40
Your Laravel ./public/ directory must be the document root of your domain. Set up your web server accordingly
MikaelNazarenko
Expert
Post by MikaelNazarenko » 25 Jul 2019, 07:23
Aaah, I understand ! Sorry, yesterday I was stupid a little bit )) So when I set public as document root then I will not have public in url and it will work. I have done it another way, you variant sure better!
MikaelNazarenko
Expert
Post by MikaelNazarenko » 25 Jul 2019, 07:55
Can you, please, explain why do I have this on /shop page ?
No catalog node for ID ""
https://prnt.sc/ojrtjz
I would like have like this:
http://laravel.demo.aimeos.org/default/en/EUR/list
MikaelNazarenko
Expert
Post by MikaelNazarenko » 25 Jul 2019, 11:36
I have fixed it just by adding demo data by executing
, but footer is missing( What might be the reason ? Or the footer is just missing in template here https://github.com/aimeos/aimeos-laravel ?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 25 Jul 2019, 12:08
Ok, now I am caring about how to remove '/shop' from url, or, I mean how to make application shows '/shop' content on '/' page ? So I want to show on my root / page the content from /shop
MikaelNazarenko
Expert
Post by MikaelNazarenko » 25 Jul 2019, 14:52
Nice, I have done it by adding the following code to my routes/web.php :
Route::get('/', array(
    'as' => 'aimeos_shop_list',
    'uses' => '\Aimeos\Shop\Controller\CatalogController@listAction'
