Check if admin is already logged in and question about session
lucadambros
Post by lucadambros » 02 Aug 2019, 08:55
I'm creating a global middleware and I need to know if an admin user is logged in or not.
I tried
Auth::check()
but it always return false.
How do you store the session? How can I retrieve the data of the admin user and the session?
I'm using php 7.3, aimeos 2019.07.02 and laravel 5.8.
Re: Check if admin is already logged in and question about session
Post by aimeos » 02 Aug 2019, 14:43
Aimeos uses the Laravel "users" table so Auth::check() should work. Also, Aimeos uses the Laravel session so you can use it like in every other Laravel application.
lucadambros
Post by lucadambros » 02 Aug 2019, 15:12
I was creating the wrong type of middleware because I was trying to get the user before the response of the login.
I had to create a middleware like this one:
public function handle($request, Closure $next)
        $response = $next($request);
        // Perform action
        return $response;
