Foreign Key on Setup
I have the following error when installing and I get to installing the demo data. I have made the amendments to config/database.php. It is Larvel 5.8 on Linux.
SQLSTATE[HY000]: General error: 1005 Can't create table `tdbhosti_demoshop`.`users_address` (errno: 150 "Foreign key constraint is incorrectly formed")
Re: Foreign Key on Setup
What's the charset and collation of your "users" table? What are the table options in your ./config/database.php file?
I copied the changes from your instructions:
'mysql' => [
'driver' => 'mysql',
'url' => env('DATABASE_URL'),
'host' => env('DB_HOST', '127.0.0.1'),
'port' => env('DB_PORT', '3306'),
'database' => env('DB_DATABASE', 'forge'),
'username' => env('DB_USERNAME', 'forge'),
'password' => env('DB_PASSWORD', ''),
'unix_socket' => env('DB_SOCKET', ''),
'charset' => 'utf8',
'collation' => 'utf8_unicode_ci',
'prefix' => '',
'prefix_indexes' => true,
'strict' => true,
'engine' => null,
'options' => extension_loaded('pdo_mysql') ? array_filter([
PDO::MYSQL_ATTR_SSL_CA => env('MYSQL_ATTR_SSL_CA'),
'mysql' => [
'prefix' => '',
'strict' => true,
'engine' => null,
Can you please post the output of
SHOW CREATE TABLE `users`Professional support and custom implementation are available at Aimeos.com
from Navicat's table information:
CREATE TABLE `users` (
`id` int(10) unsigned NOT NULL AUTO_INCREMENT,
`name` varchar(255) COLLATE utf8_unicode_ci NOT NULL,
`email` varchar(255) COLLATE utf8_unicode_ci NOT NULL,
`email_verified_at` timestamp NULL DEFAULT NULL,
`password` varchar(255) COLLATE utf8_unicode_ci NOT NULL,
`remember_token` varchar(100) COLLATE utf8_unicode_ci DEFAULT NULL,
`created_at` datetime NOT NULL,
`updated_at` datetime NOT NULL,
`superuser` smallint(6) NOT NULL DEFAULT 0,
`siteid` int(11) DEFAULT NULL,
`label` varchar(255) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`salutation` varchar(8) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`company` varchar(100) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`vatid` varchar(32) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`title` varchar(64) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`firstname` varchar(64) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`lastname` varchar(64) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`address1` varchar(200) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`address2` varchar(200) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`address3` varchar(200) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`postal` varchar(16) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`city` varchar(200) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`state` varchar(200) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`langid` varchar(5) COLLATE utf8_unicode_ci DEFAULT NULL,
`countryid` char(2) COLLATE utf8_unicode_ci DEFAULT NULL,
`telephone` varchar(32) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`telefax` varchar(32) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`website` varchar(255) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
`longitude` decimal(8,6) DEFAULT NULL,
`latitude` decimal(8,6) DEFAULT NULL,
`birthday` date DEFAULT NULL,
`vdate` date DEFAULT NULL,
`status` smallint(6) NOT NULL DEFAULT 1,
`editor` varchar(255) COLLATE utf8_unicode_ci NOT NULL DEFAULT '',
PRIMARY KEY (`id`),
UNIQUE KEY `users_email_unique` (`email`),
KEY `idx_lvusr_langid` (`langid`),
KEY `idx_lvusr_last_first` (`lastname`,`firstname`),
KEY `idx_lvusr_post_addr1` (`postal`,`address1`),
KEY `idx_lvusr_post_city` (`postal`,`city`),
KEY `idx_lvusr_lastname` (`lastname`),
KEY `idx_lvusr_address1` (`address1`),
KEY `idx_lvusr_city` (`city`)
) ENGINE=MyISAM DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci;
PRIMARY KEY (`id`),
Which Aimeos version do you use?
Please make sure the columns "users.id" and "users_address.parentid", "users_list.parentid" "users_property.parentid" are using the same column definition. The easiest was would be to remove the "unsigned" from the users.id column.
I removed the unsiqned from the users.id and the users_address.parentid was unsigned. The tables users_list.parentid and users_property.parentid are not there. I tried to rerun the setup command but got the same error.
I downloaded from composer yesterday. Composer is showing "aimeos/aimeos-laravel": "~2018.07"
You should use the latest version which is 2019.07.
All referenced columns need the same attributes so if users_address.parentid is unsigend, users.id have to be unsigend too.
What version of MySQL (or a derivate) are you using?
I manually changed the version in composer.json (but this was only installed yesterday via composer so you may wish to look at this) and ran an update. It updated to the later version.
I tried php artisan aimeos:setup --option=setup/default/demo:1 but got the same error.
My version of mySQL is MariaDB
10.2.26-MariaDB-log-cll-lve - MariaDB Server
Can you please drop your database and rerun again so we have a clean state?
