How to generate code field ?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 06 Sep 2019, 12:51
A lot of aimeos entities have unique code field. In most cases the value based on label or name value. Is there some helper/service to generate the unique code ?
Re: How to generate code field ?
Post by aimeos » 08 Sep 2019, 08:34
No, the code fields should be used to set IDs (or references) from external systems. If you don't have an external system as source of your data, use something unique for the codes (e.g. an unique name or a hash).
MikaelNazarenko
Expert
Post by MikaelNazarenko » 09 Sep 2019, 06:48
Very useful information for me ! Because exactly for this reason I added new fields to tables! As usual I am very thankful for you !
