Get logged in customer in view
MikaelNazarenko
Expert
Post by MikaelNazarenko » 14 Oct 2019, 12:58
Hi aimeos community, tell me, please, how to get current logged in aimeos customer object in view ? Should I extend something for this ?
Re: Get logged in customer in view
Post by aimeos » 14 Oct 2019, 15:48
You have to create a HTML client decorator that add the customer object to the view:
https://aimeos.org/docs/Developers/Html ... components
You can get the customer item of the logged in user with:
$view->user = \Aimeos\Controller\Frontend::create( $context, 'customer' )->get();
MikaelNazarenko
Expert
Post by MikaelNazarenko » 14 Oct 2019, 16:17
Ok, thank you! But if I will do
, in this case I will duplicate the query to fetch user ? Because I think it is already fetched
Post by aimeos » 14 Oct 2019, 16:38
No, it isn't. Only the user ID is available in the context but the item hasn't been retrieved until you create the frontend controller.
MikaelNazarenko
Expert
Post by MikaelNazarenko » 19 Nov 2019, 09:20
The little problem is that I need user object in a lot of partials. Then I have to find all places where partials are included and pass user to them.
Can I make it simply somehow ? Make it automatically or I don't know ) then I can use user in all partials )
MikaelNazarenko
Expert
Post by MikaelNazarenko » 19 Nov 2019, 12:42
I have solved it ) Maybe will be useful for somebody:
ext/labor/client/html/src/Client/Helper/Partial/Partial.php :
<?php
namespace Aimeos\Client\Helper\Partial;
class Partial extends \Aimeos\MW\View\Helper\Partial\Standard
     * @param string $file
     * @param array $params
     * @return string
     * @throws \Aimeos\MW\View\Exception
    public function transform( $file, array $params = [] )
        $view = clone $this->getView();
        $params['user'] = $view->user;
        $view->assign( $params );
        return $view->render( $file );
ext/labor/client/html/src/Client/Html/Common/Decorator/CustomDecorator.php :
<?php
namespace Aimeos\Client\Html\Common\Decorator;
class CustomDecorator extends Base
    public function addData( \Aimeos\MW\View\Iface $view, array &$tags = array(), &$expire = null )
        $view = parent::addData( $view, $tags, $expire );
        $view->user = \Aimeos\Controller\Frontend::create( $this->getContext(), 'customer' )->get();
        $helper = new \Aimeos\Client\Helper\Partial\Partial($view);
        $view->addHelper('partial', $helper);
        return $view;
Then you will have user object in all partials )
MikaelNazarenko
Expert
Post by MikaelNazarenko » 19 Nov 2019, 13:08
aimeos wrote: 14 Oct 2019, 15:48 You have to create a HTML client decorator that add the customer object to the view:
Also as I see the above code will not return current logged in user. It will return empty user, because it is
https://github.com/aimeos/ai-controller ... rd.php#L53
Seems it should look like this:
$view->user = \Aimeos\Controller\Frontend::create( $context, 'customer' )->uses([])->get();
