user login status / group assignment in view
columbo
Post by columbo » 15 Oct 2019, 15:40
how can we check in Laravel 6 if a user is already logged-in and if so, to which user groups he belongs in a view eg. in items-body-list.php?
In Laravel blade I would check the login-status with something like:
@if (Auth::check())
  //show logged in detail-link
@else
  //show logged out detail-link
@endif
Thank you
Re: user login status / group assignment in view
Post by aimeos » 15 Oct 2019, 15:59
You can use normal PHP statements:
<?php if(Auth::check()) : ?>
<?php else : ?>
<?php endif ?>
The Blade compiler produces the same output.
