CMS & aimeos integration
columbo
Post by columbo » 25 Oct 2019, 16:25
I'm looking for a CMS & aimeos integration. Do you have a recommendation?
I already checked OctoberCMS (https://octobercms.com) but I'm not sure if its the right solution.
Does anyone have experience with that?
Thank you!
Re: CMS & aimeos integration
Post by aimeos » 25 Oct 2019, 16:59
The best integration of Aimeos into a CMS is currently the TYPO3 extension.
For the Aimeos standalone app (https://github.com/aimeos/aimeos), we want to integrate Twill (https://twill.io/) as soon as they have a release for Laravel 6 ready.
mr.zherart
Post by mr.zherart » 06 Jun 2020, 10:00
Hi, twill has released v2.0 in March with Laravel 6 and 7 support. In aimeos project roadmap nothing now about integration. It will in 2020.07 or 2020.10?
We are thinking now which CMS on Laravel better to use, Twill looks interesting. Could you reveal some details, when and how it will be integrated?
Thank you!
Post by aimeos » 06 Jun 2020, 10:48
Current plans are a integration for 2020.10 LTS but only for the aimeos/aimeos distribution. You can always add Twill yourself in your own Laravel application together with Aimeos.
