Preview images generation/rescale problem
D-Cell
Post by D-Cell » 27 Oct 2019, 20:01
Hello, dear Aimeos team!
I installed the fresh version of Aimeos (2019.10) on Laravel 6.2. Everything seems to work well, but the only problem i have is a product preview images rescale.
I would like them to have a different size in my project, so i added next lines to my shop.php:
'controller' => [
		'common' => [
			'media' => [
				'standard' => [
					'preview' => [
						'maxwidth' => 50,
						'maxheight' => 35,
						'force-size' => false
After that, i run php artisan aimeos:jobs media/scale, clear all the caches, but nothing happens to my preview images, they are still the same.
I also tried to rescale images during upload with:
'controller' => [
		'common' => [
			'media' => [
				'standard' => [
					[b]'files' [/b]=> [
						'maxwidth' => 50,
						'maxheight' => 35,
My system is Fedora 30 (GD and Imagemagick are installed).
Would be grateful, if you clarify what am i doing wrong?
Thank you!
Re: Preview images generation/rescale problem
Post by aimeos » 28 Oct 2019, 08:55
You have to use the new "previews" key: https://github.com/aimeos/aimeos-core/b ... hp#L31-L43
Is there any old documentation we forgot to update?
D-Cell
Post by D-Cell » 28 Oct 2019, 20:28
aimeos wrote: 28 Oct 2019, 08:55 You have to use the new "previews" key: https://github.com/aimeos/aimeos-core/b ... hp#L31-L43
Hi! Thank you for reply! The way you provided works perfect. :D
I used this particle to work with thumbnails before - https://aimeos.org/docs/Configuration/C ... mmon/media There are some settings, which didn`t work for me, among others.
Many thanks! Great team and great system!
