Customer manager save event
MikaelNazarenko
Expert
Post by MikaelNazarenko » 29 Oct 2019, 14:40
I need to export customer when it was saved. But not in all cases. In some case it must not do import. I have added logic to my custom customer manager saveItem() method. But problem is that I can't tell to manager when I don't need to make export or another action. I need make export of customer when it was saved on admin panel or front-end. I tried to add field 'makeExport' to manager or customer entity but it still makes export when I don't need it.... Can you, please, suggest me something.. ? I hope my problem is understandable )
Re: Customer manager save event
Post by aimeos » 30 Oct 2019, 07:14
Add your decorator only for frontend and backend but not for command in your ./config/shop.php:
https://github.com/aimeos/aimeos-larave ... #L104-L108
MikaelNazarenko
Expert
Post by MikaelNazarenko » 30 Oct 2019, 08:16
Thank you! But can you please clarify how this settings with decorator must look like:
	'frontend' => [
	'backend' => [
And how the decorator must look like for this specific case ? Ideally it must catch the customer saving. So when customer saved from backend or frontend - my logic will do necessary things
Post by aimeos » 31 Oct 2019, 08:47
You have to implement the saveItem() and saveItems() method in your manager decorator:
https://aimeos.org/docs/Developers/Libr ... s#Easy_way
Configuration for frontend and backend would be:
'frontend' => [
    'customer' => [
        'manager' => [
            'decorators' => [
                'local' => ['Myproject']
'backend' => [
    'customer' => [
        'manager' => [
            'decorators' => [
MikaelNazarenko
Expert
Post by MikaelNazarenko » 31 Oct 2019, 09:29
Aimeos, thank you very much !!
MikaelNazarenko
Expert
Post by MikaelNazarenko » 31 Oct 2019, 11:34
One moment, it that documentation from your post, the class \Aimeos\MShop\Common\Manager\Decorator doesn't exist in newest versions of Aimeos. Which class should I use ? I guess \Aimeos\MShop\Common\Manager\Decorator\Base this one ?
My config looks like:
	'backend' => [
	    'customer' => [
	        'manager' => [
	            'decorators' => [
	                'local' => ['Customer']
My decorator:
namespace Aimeos\MShop\Customer\Manager\Decorator;
class Customer extends \Aimeos\MShop\Common\Manager\Decorator\Base
    public function saveItem( \Aimeos\MShop\Common\Item\Iface $item, $fetch = true )
        die;
        // do something before
        $result = $this->getManager()->saveItem( $item, $fetch );
        // do somthing afterwards
        return $result;
But when I save some customer in backend nothing happens..
What the problem ?
Versions of the components:
aimeos/ai-admin-jqadm                 2019.10.3 Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm               2019.10.1 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html                 2019.10.4 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi              2019.10.1 Aimeos JSON API extension
aimeos/ai-controller-frontend         2019.10.2 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs             2019.10.2 Aimeos ai-controller-jobs extension
aimeos/ai-gettext                     2019.10.1 Aimeos Gettext extension
aimeos/ai-laravel                     2019.10.1 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments                    2019.10.1 Payment extension for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer                 2019.10.1 SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core                    2019.10.2 Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel                 2019.10.1 Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
MikaelNazarenko
Expert
Post by MikaelNazarenko » 05 Nov 2019, 16:21
Are you sure that it works ? For me doesn't.. And I can't find documentation for this for 2019 version..
Post by aimeos » 05 Nov 2019, 16:26
Indeed, it's
class Myproject extends \Aimeos\MShop\Common\Manager\Decorator\Base
Sorry for that, documentation is fixed.
MikaelNazarenko
Expert
Post by MikaelNazarenko » 05 Nov 2019, 16:58
My problem is because nothing happens when I save the customer from admin panel (back-end). But there is a die; I described my files in couple posts above..
This is my decorators path /var/www/schmuck/ext/labor/lib/custom/src/MShop/Customer/Manager/Decorator/Customer.php
And decorator looks like:
        die;
        return $result;
I can't understand what is the problem.. I also tried to set wrong decorator in settings like:
	'backend' => [
	    'customer' => [
	        'manager' => [
	            'decorators' => [
	                'local' => ['CustomerNotExisting']
But no any errors....
Maybe because I extended customer manager and sqls for insert, update, search.. But it should not..
Thanks for the help !
Post by aimeos » 05 Nov 2019, 17:22
MikaelNazarenko wrote: 05 Nov 2019, 16:58
	'backend' => [
	    'customer' => [
	        'manager' => [
	            'decorators' => [
You forgot the "mshop" key in your config:
'backend' => [
    'mshop' => [
        'customer' => [
            'manager' => [
                'decorators' => [
