Aimeos mysql requirements
MikaelNazarenko
Expert
Post by MikaelNazarenko » 08 Nov 2019, 16:18
Good evening, I got problem
Aimeos version is:
aimeos/ai-laravel                     2019.10.1
MySQL:
mysqld  Ver 5.6.21 for Linux on i686 (Source distribution)
The problem is when I execute artisan aimeos:setup, error text is:
 Aimeos\MW\DB\Exception  : SQLSTATE[HY000]: General error: 1709 Index column size too large. The maximum column size is 767 bytes.: CREATE TABLE mshop_locale_site (id INT AUTO_INCREMENT NOT NULL, parentid INT NOT NULL, code VARCHAR(255) NOT NULL, `label` VARCHAR(255) NOT NULL, config TEXT NOT NULL, level SMALLINT NOT NULL, nleft INT NOT NULL, nright INT NOT NULL, status SMALLINT NOT NULL, mtime DATETIME NOT NULL, ctime DATETIME NOT NULL, editor VARCHAR(255) NOT NULL, UNIQUE INDEX unq_mslocsi_code (code), INDEX idx_mslocsi_nlt_nrt_lvl_pid (nleft, nright, level, parentid), INDEX idx_mslocsi_level_status (level, status), PRIMARY KEY(id)) DEFAULT CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci ENGINE = InnoDB
  at /kunden/527257_50389/webseiten/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/DB/Statement/DBAL/Simple.php:94
    90|
    91| 		try {
    92| 			$result = $this->exec();
    93| 		} catch( \PDOException $e ) {
  > 94| 			throw new \Aimeos\MW\DB\Exception( $e->getMessage() . ': ' . $this->sql, $e->getCode() );
    95| 		}
    96|
    97| 		return new \Aimeos\MW\DB\Result\PDO( $result );
    98| 	}
  Exception trace:
  1   Aimeos\MW\DB\Statement\DBAL\Simple::execute()
      /kunden/527257_50389/webseiten/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Task/Base.php:177
  2   Aimeos\MW\Setup\Task\Base::executeList("db-locale")
      /kunden/527257_50389/webseiten/vendor/aimeos/aimeos-core/lib/mshoplib/setup/TablesCreateMShop.php:197
It is very important for me. Please, tell me if I have chance to make it work on MySQL 5.6.21 ? Or it is crazy and I have to rename a lot of indexes and it affects a lot of points ?
Thank you very much !
Re: Aimeos mysql requirements
Post by aimeos » 08 Nov 2019, 16:19
MikaelNazarenko
Expert
Post by MikaelNazarenko » 08 Nov 2019, 17:49
Oh sorry, I have not checked documentation carefully. But now another problem, when I executed aimeos:setup
 Doctrine\DBAL\Schema\SchemaException  : There is no table with name 'db527257_4.users' in the schema.
  at /kunden/527257_50389/webseiten/vendor/doctrine/dbal/lib/Doctrine/DBAL/Schema/SchemaException.php:30
    26|      * @return \Doctrine\DBAL\Schema\SchemaException
    27|      */
    28|     public static function tableDoesNotExist($tableName)
    29|     {
  > 30|         return new self("There is no table with name '" . $tableName . "' in the schema.", self::TABLE_DOESNT_EXIST);
    31|     }
    32|
    33|     /**
    34|      * @param string $indexName
  Exception trace:
  1   Doctrine\DBAL\Schema\SchemaException::tableDoesNotExist("db527257_4.users")
      /kunden/527257_50389/webseiten/vendor/doctrine/dbal/lib/Doctrine/DBAL/Schema/Schema.php:168
  2   Doctrine\DBAL\Schema\Schema::getTable("db527257_4.users")
      /kunden/527257_50389/webseiten/ext/labor/lib/custom/setup/default/schema/customer.php:13
  3   Aimeos\MW\Setup\Task\TablesCreateMShop::{closure}(Object(Doctrine\DBAL\Schema\Schema))
      /kunden/527257_50389/webseiten/vendor/aimeos/aimeos-core/lib/mshoplib/setup/TablesCreateMShop.php:153
  4   Aimeos\MW\Setup\Task\TablesCreateMShop::getSchemaObjects("table", "default/schema/customer.php", Object(Doctrine\DBAL\Schema\SchemaConfig))
      /kunden/527257_50389/webseiten/vendor/aimeos/aimeos-core/lib/mshoplib/setup/TablesCreateMShop.php:186
  5   Aimeos\MW\Setup\Task\TablesCreateMShop::setupSchema()
      /kunden/527257_50389/webseiten/vendor/aimeos/aimeos-core/lib/mshoplib/setup/TablesCreateMShop.php:107
  6   Aimeos\MW\Setup\Task\TablesCreateMShop::migrate()
      /kunden/527257_50389/webseiten/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Manager/Multiple.php:177
  7   Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
      /kunden/527257_50389/webseiten/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Manager/Multiple.php:173
  8   Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
      /kunden/527257_50389/webseiten/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Manager/Multiple.php:98
  9   Aimeos\MW\Setup\Manager\Multiple::migrate(Object(Aimeos\MW\Setup\Task\TablesCreateMAdmin))
      /kunden/527257_50389/webseiten/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/SetupCommand.php:78
  10  Aimeos\Shop\Command\SetupCommand::handle()
      /kunden/527257_50389/webseiten/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:32
  11  call_user_func_array([])
  12  Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
      /kunden/527257_50389/webseiten/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:90
  13  Illuminate\Container\BoundMethod::callBoundMethod(Object(Illuminate\Foundation\Application), Object(Closure))
      /kunden/527257_50389/webseiten/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:34
  14  Illuminate\Container\BoundMethod::call(Object(Illuminate\Foundation\Application), [])
      /kunden/527257_50389/webseiten/vendor/laravel/framework/src/Illuminate/Container/Container.php:576
  15  Illuminate\Container\Container::call()
      /kunden/527257_50389/webseiten/vendor/laravel/framework/src/Illuminate/Console/Command.php:183
  16  Illuminate\Console\Command::execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
      /kunden/527257_50389/webseiten/vendor/symfony/console/Command/Command.php:255
  17  Symfony\Component\Console\Command\Command::run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
      /kunden/527257_50389/webseiten/vendor/laravel/framework/src/Illuminate/Console/Command.php:170
  18  Illuminate\Console\Command::run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
      /kunden/527257_50389/webseiten/vendor/symfony/console/Application.php:934
  19  Symfony\Component\Console\Application::doRunCommand(Object(Aimeos\Shop\Command\SetupCommand), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
      /kunden/527257_50389/webseiten/vendor/symfony/console/Application.php:273
  20  Symfony\Component\Console\Application::doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
      /kunden/527257_50389/webseiten/vendor/symfony/console/Application.php:149
  21  Symfony\Component\Console\Application::run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
      /kunden/527257_50389/webseiten/vendor/laravel/framework/src/Illuminate/Console/Application.php:90
  22  Illuminate\Console\Application::run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
      /kunden/527257_50389/webseiten/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:133
  23  Illuminate\Foundation\Console\Kernel::handle(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
      /kunden/527257_50389/webseiten/artisan:37
But users table exists, I executed artisan migrate before it
MikaelNazarenko
Expert
Post by MikaelNazarenko » 08 Nov 2019, 18:03
it is on live server with mysql 5.6.. But on my local it works, code the same..
MikaelNazarenko
Expert
Post by MikaelNazarenko » 08 Nov 2019, 18:13
This is from ext/labor/lib/custom/setup/default/schema/customer.php :
return array(
	'table' => array(
		'users' => function ( \Doctrine\DBAL\Schema\Schema $schema ) {
			$table = $schema->getTable( 'users' );
			$table->addColumn('id_customer', 'bigint')->setUnsigned(true)->setNotnull(false);
			$table->addColumn('id_customer_ref', 'bigint')->setUnsigned(true)->setNotnull(false);
			$table->addColumn('cellphone', 'string')->setDefault('')->setLength(32);
			$table->addColumn('bic', 'string')->setDefault('')->setLength(200);
			$table->addColumn('bank', 'string')->setDefault('')->setLength(200);
			$table->addColumn('iban', 'string')->setDefault('')->setLength(30);
			$table->addColumn('payment_id', 'smallint')->setNotnull(false);
			$table->addColumn('values', 'string')->setDefault('')->setLength(200);  // show near name in downline
			$table->addColumn('postal_number', 'string')->setDefault('')->setLength(200);
			$table->addColumn('postal_station', 'string')->setDefault('')->setLength(200);
			$table->addColumn('discount', 'float')->setDefault(0);
			$table->addColumn('discount_from', 'float')->setDefault(0); //date from
			$table->addColumn('discount_to', 'float')->setDefault(0); //date_to
			$table->addColumn('discount_type', 'smallint')->setNotnull(false)->setUnsigned(true);
			$table->addColumn('fair_code', 'integer')->setNotnull(false);
            $table->addColumn('price_group', 'smallint')->setNotnull(false)->setUnsigned(true);
            $table->dropColumn('birthday');
            $table->addColumn('birthday', 'integer')->setNotnull(false);
            $table->addColumn('sales_tax', 'float')->setDefault(0);
            $table->addUniqueIndex(['id_customer'], 'unq_lvusr_idcustomer' );
			return $schema;
But it works on other environments.. May it be because of mysql version.. ? sounds stupid
MikaelNazarenko
Expert
Post by MikaelNazarenko » 08 Nov 2019, 18:19
'ai-laravel' added to manifest solved the problem. But why it worked on other environments I don't know )
Post by aimeos » 09 Nov 2019, 11:31
If you don't add the dependencies correctly, the order of execution will be random. Thus the order used locally worked but on the server a different order was used and failed.
