Change countries list on back-end
MikaelNazarenko
Expert
Post by MikaelNazarenko » 13 Nov 2019, 17:10
I need to customize countries list on customer page on back-end.
As I see it is done here:
Aimeos.Customer = {
	init : function() {
		this.setupComponents();
		Aimeos.Customer.Product.init();
	select: function(ev, ui) {
		var node = $(ev.delegateTarget);
		node.closest("card-block").find("input.item-countryid").val(node.val());
	setupComponents : function() {
		$(".item-customer .item-countryid.combobox").combobox({
			getfcn: Aimeos.getCountries,
			select: Aimeos.Customer.select
How can I do it elegantly ? I need remove unnecessary countries from list.
Thank you!
Re: Change countries list on back-end
Post by aimeos » 14 Nov 2019, 07:57
Overwrite the "Aimeos.getCountries" function to return only those countries you want to show.
