Locale template (separate language and currency)
aloniwe
Post by aloniwe » 21 Nov 2019, 13:00
Hi, i want to separate language and currency subparts from the locale template to paste them in different places of my page.
If there are opportunity to divide theme like filter component into tree/attribute? What should i do?
Re: Locale template (separate language and currency)
Post by aimeos » 23 Nov 2019, 08:21
The best way might be to implement that code in your Laravel application and generate output for both drop-down in the main Blade template:
https://github.com/aimeos/ai-client-htm ... #L356-L373
Here you can learn how to get the context:
https://aimeos.org/docs/Laravel/Extend_Aimeos
aloniwe
Post by aloniwe » 27 Nov 2019, 13:46
It works, thank you aimeos!
