Responsive Images job Issue
awaidqureshi
Post by awaidqureshi » 08 Jan 2020, 07:30
When i run aimeos:jobs media/scale command its running successfully, but its not generating all 3 previews for all products what can be the issue
Please guide me how i can generate all 3 preview images for all products
Re: Responsive Images job Issue
Post by aimeos » 08 Jan 2020, 16:12
Make sure that:
- Your configuration contains the preview file sizes you want (https://github.com/aimeos/aimeos-core/b ... hp#L31-L43)
- Your images are big enough (images aren't scaled up)
- The records in the mshop_media table contains an "image/*" mime type
- The file mtime is newer than the mshop_media.mtime
awaidqureshi
Post by awaidqureshi » 09 Jan 2020, 05:26
aimeos wrote: 08 Jan 2020, 16:12 Make sure that:
Poitn#1. Configuraton file has all preview file sizes.
Poitn#3. mshop_media have specific images type means in my case all pictures have mime type image/png.
Poitn#2.How to overcome this big images issue.
Poitn#4. how can i solve mtime issue if is there any ?
Post by aimeos » 09 Jan 2020, 12:00
awaidqureshi wrote: 09 Jan 2020, 05:26 Poitn#2.How to overcome this big images issue.
Upload bigger images
awaidqureshi wrote: 09 Jan 2020, 05:26 Poitn#4. how can i solve mtime issue if is there any ?
You can use the Unix "touch" command to update the file mtime of your images.
