Hook into order completing process
flomo
Post by flomo » 20 Jan 2020, 11:01
As soon as an order has been paid, I need to make an API call to fetch a serial number, store the serial with the order and send it to the customer with the payment email.
I'm a bit lost:
1. Where can I hook into the order complete process to start my API calls (the order must be fully paid at this moment)?
2. Where would I store the serial to, so the user can view it in his account?
Ideally this should happen before the confirmation is sent to the customer, to include the serial in the email.
Re: Hook into order completing process
Post by aimeos » 21 Jan 2020, 09:46
The best way is to create a decorator for the payment service provider:
- https://aimeos.org/docs/Developers/Libr ... _decorator
- https://aimeos.org/docs/Developers/Library/Service
Then, in your decorator:
- add the updateSync() (called after redirecting the customer to the confirmation page) method
- add updatePush() (called by the payment server in an asynchon way if the payment status changes) methods
- check if the payment status is what you need (authorized or received)
- fetch the order base object (basket) with the services (payment and delivery)
- check if the serial number is already set as order service attribute
- make your API calls
- store the serial number as order service attribute
- store the order base object again
There are helper/support methods for almost everything documented. The rest (serial number is shown to the customers in their accounts and in their e-mails) is done automatically as long as you don't use a order service attribute type "hidden".
flomo
Post by flomo » 21 Jan 2020, 09:59
Thank you very much! Will dive into this this week.
flomo
Post by flomo » 24 Jan 2020, 11:27
How would I get the basket/products? I was able to fetch the basket, but the products are always empty:
    public function updateSync(\Psr\Http\Message\ServerRequestInterface $request, \Aimeos\MShop\Order\Item\Iface $orderItem)
        $update = $this->getProvider()->updateSync($request, $orderItem);
        // Returns []
        dump($this->getProvider()->getOrderBase($orderItem->getBaseId())->getProducts());
        // Returns []
        dump($this->getOrderBase($orderItem->getBaseId())->getProducts());
        return $update;
flomo
Post by flomo » 24 Jan 2020, 14:05
:? Nevermind. I just found out, that
\Aimeos\MShop\Service\Provider\Base::getOrderBase()
accepts a second parameter that defines, which part of the order to load: https://aimeos.org/api/latest/class-Aim ... .Base.html
Using
\Aimeos\MShop\Order\Item\Base\Base::PARTS_ALL
or
\Aimeos\MShop\Order\Item\Base\Base::PARTS_PRODUCT
(defined here https://aimeos.org/api/latest/class-Aim ... .Base.html) solves the problem.
flomo
Post by flomo » 24 Jan 2020, 16:05
Still having problems. I now have the Aimeos\MShop\Order\Item\Base\Product\Standard objects from the order, but the supplier ( getSupplierCode() ) and attributes ( getAttribute(), the function getAttributes() is even not available) are empty. How can I access this data?
Post by aimeos » 25 Jan 2020, 14:21
The supplier code is only added if it's passed when adding it to the basket. This isn't done by default because there can be several suppliers for one product.
These are the methods available for retrieving attributes of an order product item:
https://github.com/aimeos/aimeos-core/b ... #L289-L313
flomo
Post by flomo » 25 Jan 2020, 17:11
I tried those methods, but getAttributeItem() returns null, and getAttributeItems() an empty array [] with this code:
        $basket = $this->getOrderBase($orderItem->getBaseId(), OrderItemBaseBase::PARTS_ALL);
        $products = $basket->getProducts();
        foreach($products as $product) {
            $product->getAttributeItems());
I had to use this code, to get the attribute value:
        $baseManager = \Aimeos\MShop::create($this->getContext(), 'product');
        foreach ($products as $product) {
            $item = $baseManager->getItem($product->getProductId(), ['attribute']);
            $serialApi = $item->getRefItems('attribute', 'serialapi');
            if (!empty($serialApi)) {
                $serialApiValue = reset($serialApi)->getCode();
Is that ok this way?
Post by aimeos » 25 Jan 2020, 17:18
No, you didn't store the serial ID as order product attribute but as regular product referencing a regular attribute instead! That way, your serial ID is shared for all orders and if there will be two orders at the same time, they will both retrieve the same serial ID.
flomo
Post by flomo » 25 Jan 2020, 17:27
The code in my previous post ist not about the serial yet. I store an API reference called "serialapi" (each product might get its serial from another API, depending on the brand) with each product. After payment I have to retrieve this reference to know, which API I have to contact.
So I think the idea is correct, I'm just not sure if my complicated code is correct (because $product->getAttributeItems() returns an empty array).
