integration of web tracking, event tracking
columbo
Post by columbo » 24 Jan 2020, 11:57
are there already any web-tracking and / or event-tracking functions (like "add to cart", "checkout confirm" etc.) for e.g. Google Anayltics, Piwik PRO or Matomo prepared? If not, are there any recommendations or documents how to do?
Thank’s
Re: integration of web tracking, event tracking
Post by aimeos » 25 Jan 2020, 14:23
Not yet. You should add the tracking codes to the base application template if you need page tracking only (analyzing the funnel) or add it to the Aimeos component templates if you want to do more detailed tracking (like analyzing the products added to the basket).
