Adding Telephone in Checkout Address as a Mandatory Field
Amir
Post by Amir » 19 Feb 2020, 18:09
I want to add the telephone number as a mandatory field.
What I've done is adding it to billing standard.php
	private $mandatory = array(
		'order.base.address.email',
		'order.base.address.firstname',
		'order.base.address.telephone',
		'order.base.address.address1',
		'order.base.address.city',
		'order.base.address.countryid',
And I've changed the html in address Partial standard as follows
	<div class="col <?= ( isset( $css['order.base.address.telephone'] ) ? join( ' ', $css['order.base.address.telephone'] ) : '' ); ?>" data-regex="<?= $testfcn( $regex, 'order.base.address.telephone' ); ?>">
	<input type="tel" class="form-control" id="address-<?= $type ?>-telephone<?= $idstr ?>" name="<?= $enc->attr( $this->formparam( array( $fname, 'order.base.address.telephone' ) ) ); ?>"
			value="<?= $enc->attr( $testfcn( $addr, 'order.base.address.telephone' ) ); ?>" placeholder="<?= $enc->attr( $this->translate( 'client', 'Telephone' ) ); ?>"	<?= $disablefcn( $css, 'order.base.address.telephone' ); ?> >
	</div>
but the phone is displayed in disabled mode. How to achieve that.
Re: Adding Telephone in Checkout Address as a Mandatory Field
Post by aimeos » 20 Feb 2020, 11:15
You only have to change the configuration and add "order.base.address.telephone" to the mandatory list:
https://aimeos.org/docs/Configuration/C ... /mandatory
You can also change this for the delivery address separately and modify the optional and hidden fields.
