installation problem
AnemerTigris
Post by AnemerTigris » 03 Mar 2020, 17:55
Please Help me!
Updating dependencies (including require-dev)
Your requirements could not be resolved to an installable set of packages.
Problem 1
- aimeos/aimeos-laravel 2019.10.1 requires aimeos/aimeos-core 2019.10.* -> satisfiable by aimeos/aimeos-core[2019.10.1, 2019.10.10, 2019.10.11, 2019.10.12, 2019.10.13, 2019.10.14, 2019.10.15, 2019.10.16, 2019.10.17, 2019.10.18, 2019.10.19, 2019.10.2, 2019.10.3, 2019.10.4, 2019.10.5, 2019.10.6, 2019.10.7, 2019.10.8, 2019.10.9, 2019.10.x-dev].
- aimeos/aimeos-laravel 2019.10.2 requires aimeos/aimeos-core 2019.10.* -> satisfiable by aimeos/aimeos-core[2019.10.1, 2019.10.10, 2019.10.11, 2019.10.12, 2019.10.13, 2019.10.14, 2019.10.15, 2019.10.16, 2019.10.17, 2019.10.18, 2019.10.19, 2019.10.2, 2019.10.3, 2019.10.4, 2019.10.5, 2019.10.6, 2019.10.7, 2019.10.8, 2019.10.9, 2019.10.x-dev].
- aimeos/aimeos-laravel 2019.10.x-dev requires aimeos/aimeos-core 2019.10.* -> satisfiable by aimeos/aimeos-core[2019.10.1, 2019.10.10, 2019.10.11, 2019.10.12, 2019.10.13, 2019.10.14, 2019.10.15, 2019.10.16, 2019.10.17, 2019.10.18, 2019.10.19, 2019.10.2, 2019.10.3, 2019.10.4, 2019.10.5, 2019.10.6, 2019.10.7, 2019.10.8, 2019.10.9, 2019.10.x-dev].
- aimeos/aimeos-core 2019.10.x-dev requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.9 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.8 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.7 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.6 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.5 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.4 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.3 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.2 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.19 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.18 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.17 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.16 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.15 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.14 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.13 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.12 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.11 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.10 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.10.1 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- Installation request for aimeos/aimeos-laravel ~2019.10 -> satisfiable by aimeos/aimeos-laravel[2019.10.1, 2019.10.2, 2019.10.x-dev].
To enable extensions, verify that they are enabled in your .ini files:
- /etc/php/7.3/cli/php.ini
- /etc/php/7.3/cli/conf.d/10-mysqlnd.ini
- /etc/php/7.3/cli/conf.d/10-opcache.ini
- /etc/php/7.3/cli/conf.d/10-pdo.ini
- /etc/php/7.3/cli/conf.d/15-xml.ini
- /etc/php/7.3/cli/conf.d/20-bz2.ini
- /etc/php/7.3/cli/conf.d/20-calendar.ini
- /etc/php/7.3/cli/conf.d/20-ctype.ini
- /etc/php/7.3/cli/conf.d/20-curl.ini
- /etc/php/7.3/cli/conf.d/20-dom.ini
- /etc/php/7.3/cli/conf.d/20-exif.ini
- /etc/php/7.3/cli/conf.d/20-fileinfo.ini
- /etc/php/7.3/cli/conf.d/20-ftp.ini
- /etc/php/7.3/cli/conf.d/20-gd.ini
- /etc/php/7.3/cli/conf.d/20-gettext.ini
- /etc/php/7.3/cli/conf.d/20-iconv.ini
- /etc/php/7.3/cli/conf.d/20-json.ini
- /etc/php/7.3/cli/conf.d/20-mbstring.ini
- /etc/php/7.3/cli/conf.d/20-mysqli.ini
- /etc/php/7.3/cli/conf.d/20-pdo_mysql.ini
- /etc/php/7.3/cli/conf.d/20-phar.ini
- /etc/php/7.3/cli/conf.d/20-posix.ini
- /etc/php/7.3/cli/conf.d/20-readline.ini
- /etc/php/7.3/cli/conf.d/20-shmop.ini
- /etc/php/7.3/cli/conf.d/20-simplexml.ini
- /etc/php/7.3/cli/conf.d/20-sockets.ini
- /etc/php/7.3/cli/conf.d/20-sysvmsg.ini
- /etc/php/7.3/cli/conf.d/20-sysvsem.ini
- /etc/php/7.3/cli/conf.d/20-sysvshm.ini
- /etc/php/7.3/cli/conf.d/20-tokenizer.ini
- /etc/php/7.3/cli/conf.d/20-wddx.ini
- /etc/php/7.3/cli/conf.d/20-xmlreader.ini
- /etc/php/7.3/cli/conf.d/20-xmlwriter.ini
- /etc/php/7.3/cli/conf.d/20-xsl.ini
- /etc/php/7.3/cli/conf.d/20-zip.ini
You can also run `php --ini` inside terminal to see which files are used by PHP in CLI mode
Re: installation problem
Post by aimeos » 04 Mar 2020, 15:22
You need to install the PHP "intl" extension
