How to extend Basket/Standard.php
Harpal Singh
Post by Harpal Singh » 06 Mar 2020, 07:29
I want to customise
ext/ai-client-html/client/html/src/Client/Html/Basket/Standard/Standard.php
How should I add and use this file in my extension?
Please help.
Re: How to extend Basket/Standard.php
Post by aimeos » 07 Mar 2020, 10:51
First, have a look if you can achieve what you need by implementing a decorator:
https://aimeos.org/docs/Developers/Html ... components
If not, create a new file in your own extension that extends from the standard class:
ext/myproject/client/html/src/Client/Html/Basket/Standard/Myproject.php
Overwrite the method you need to change and configure your new class so it will be used:
https://aimeos.org/docs/Configuration/C ... ndard/name
