Language switching in product detail issue
Kaizer
Post by Kaizer » 10 Mar 2020, 15:24
I'm having an issue when switching language in a product detail page.
When selecting a product from the catalog list, I land on a working product detail page with this url :
http://example.com/shop/productname/0
But when switching to english (my default locale is french), the url is http://example.com/shop/productname/0/en?currency=EUR and i get this error message :
Item with ID "en" in "product.id" not found
Also, after having added text descriptions and name to the product, the url then changes to
http://example.com/shop/productname/en/eur
leading to a 404
Am I doing something wrong here ? Thanks in advance !
Re: Language switching in product detail issue
Post by aimeos » 10 Mar 2020, 17:56
Which Aimeos version are you using? Can you post the output of
composer show
Kaizer
Post by Kaizer » 11 Mar 2020, 13:38
Here you go:
aimeos/ai-admin-jqadm                 2019.10.11 Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm               2019.10.4  Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html                 2019.10.13 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi              2019.10.4  Aimeos JSON API extension
aimeos/ai-controller-frontend         2019.10.9  Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs             2019.10.10 Aimeos ai-controller-jobs extension
aimeos/ai-gettext                     2019.10.1  Aimeos Gettext extension
aimeos/ai-laravel                     2019.10.5  Laravel adapter for Aimeos web shops and e-commerce so...
aimeos/ai-swiftmailer                 2019.10.1  SwiftMailer adapter for Aimeos web shops and e-commerc...
aimeos/aimeos-core                    2019.10.19 Full-featured e-commerce components for high performan...
aimeos/aimeos-laravel                 2019.10.2  Professional, full-featured and high performance Larav...
beyondcode/laravel-dump-server        1.3.0      Symfony Var-Dump Server for Laravel
composer/installers                   v1.8.0     A multi-framework Composer library installer
dnoegel/php-xdg-base-dir              v0.1.1     implementation of xdg base directory specification for...
doctrine/cache                        1.10.0     PHP Doctrine Cache library is a popular cache implemen...
doctrine/dbal                         v2.9.3     Powerful PHP database abstraction layer (DBAL) with ma...
doctrine/event-manager                1.1.0      The Doctrine Event Manager is a simple PHP event syste...
doctrine/inflector                    1.3.1      Common String Manipulations with regard to casing and ...
doctrine/instantiator                 1.3.0      A small, lightweight utility to instantiate objects in...
doctrine/lexer                        1.0.2      PHP Doctrine Lexer parser library that can be used in ...
dragonmantank/cron-expression         v2.3.0     CRON for PHP: Calculate the next or previous run date ...
egulias/email-validator               2.1.17     A library for validating emails against several RFCs
erusev/parsedown                      1.7.4      Parser for Markdown.
fideloper/proxy                       4.3.0      Set trusted proxies for Laravel
filp/whoops                           2.7.1      php error handling for cool kids
fzaninotto/faker                      v1.9.1     Faker is a PHP library that generates fake data for you.
hamcrest/hamcrest-php                 v2.0.0     This is the PHP port of Hamcrest Matchers
jakub-onderka/php-console-color       v0.2
jakub-onderka/php-console-highlighter v0.4       Highlight PHP code in terminal
laravel/framework                     v5.8.37    The Laravel Framework.
laravel/tinker                        v1.0.10    Powerful REPL for the Laravel framework.
league/flysystem                      1.0.64     Filesystem abstraction: Many filesystems, one API.
mockery/mockery                       1.3.1      Mockery is a simple yet flexible PHP mock object frame...
monolog/monolog                       1.25.3     Sends your logs to files, sockets, inboxes, databases ...
myclabs/deep-copy                     1.9.5      Create deep copies (clones) of your objects
nesbot/carbon                         2.31.0     An API extension for DateTime that supports 281 differ...
nikic/php-parser                      v4.3.0     A PHP parser written in PHP
nunomaduro/collision                  v3.0.1     Cli error handling for console/command-line PHP applic...
opis/closure                          3.5.1      A library that can be used to serialize closures (anon...
paragonie/random_compat               v9.99.99   PHP 5.x polyfill for random_bytes() and random_int() f...
phar-io/manifest                      1.0.3      Component for reading phar.io manifest information fro...
phar-io/version                       2.0.1      Library for handling version information and constraints
phpdocumentor/reflection-common       2.0.0      Common reflection classes used by phpdocumentor to ref...
phpdocumentor/reflection-docblock     4.3.4      With this component, a library can provide support for...
phpdocumentor/type-resolver           1.0.1      A PSR-5 based resolver of Class names, Types and Struc...
phpoption/phpoption                   1.7.2      Option Type for PHP
phpspec/prophecy                      v1.10.2    Highly opinionated mocking framework for PHP 5.3+
phpunit/php-code-coverage             6.1.4      Library that provides collection, processing, and rend...
phpunit/php-file-iterator             2.0.2      FilterIterator implementation that filters files based...
phpunit/php-text-template             1.2.1      Simple template engine.
phpunit/php-timer                     2.1.2      Utility class for timing
phpunit/php-token-stream              3.1.1      Wrapper around PHP's tokenizer extension.
phpunit/phpunit                       7.5.20     The PHP Unit Testing framework.
psr/container                         1.0.0      Common Container Interface (PHP FIG PSR-11)
psr/http-message                      1.0.1      Common interface for HTTP messages
psr/log                               1.1.2      Common interface for logging libraries
psr/simple-cache                      1.0.1      Common interfaces for simple caching
psy/psysh                             v0.9.12    An interactive shell for modern PHP.
ramsey/uuid                           3.9.3      Formerly rhumsaa/uuid. A PHP 5.4+ library for generati...
sebastian/code-unit-reverse-lookup    1.0.1      Looks up which function or method a line of code belon...
sebastian/comparator                  3.0.2      Provides the functionality to compare PHP values for e...
sebastian/diff                        3.0.2      Diff implementation
sebastian/environment                 4.2.3      Provides functionality to handle HHVM/PHP environments
sebastian/exporter                    3.1.2      Provides the functionality to export PHP variables for...
sebastian/global-state                2.0.0      Snapshotting of global state
sebastian/object-enumerator           3.0.3      Traverses array structures and object graphs to enumer...
sebastian/object-reflector            1.1.1      Allows reflection of object attributes, including inhe...
sebastian/recursion-context           3.0.0      Provides functionality to recursively process PHP vari...
sebastian/resource-operations         2.0.1      Provides a list of PHP built-in functions that operate...
sebastian/version                     2.0.1      Library that helps with managing the version number of...
swiftmailer/swiftmailer               v6.2.3     Swiftmailer, free feature-rich PHP mailer
symfony/console                       v4.4.5     Symfony Console Component
symfony/css-selector                  v4.4.5     Symfony CssSelector Component
symfony/debug                         v4.4.5     Symfony Debug Component
symfony/error-handler                 v4.4.5     Symfony ErrorHandler Component
symfony/event-dispatcher              v4.4.5     Symfony EventDispatcher Component
symfony/event-dispatcher-contracts    v1.1.7     Generic abstractions related to dispatching event
symfony/finder                        v4.4.5     Symfony Finder Component
symfony/http-foundation               v4.4.5     Symfony HttpFoundation Component
symfony/http-kernel                   v4.4.5     Symfony HttpKernel Component
symfony/mime                          v4.4.5     A library to manipulate MIME messages
symfony/polyfill-ctype                v1.14.0    Symfony polyfill for ctype functions
symfony/polyfill-iconv                v1.14.0    Symfony polyfill for the Iconv extension
symfony/polyfill-intl-idn             v1.14.0    Symfony polyfill for intl's idn_to_ascii and idn_to_ut...
symfony/polyfill-mbstring             v1.14.0    Symfony polyfill for the Mbstring extension
symfony/polyfill-php72                v1.14.0    Symfony polyfill backporting some PHP 7.2+ features to...
symfony/polyfill-php73                v1.14.0    Symfony polyfill backporting some PHP 7.3+ features to...
symfony/process                       v4.4.5     Symfony Process Component
symfony/psr-http-message-bridge       v1.3.0     PSR HTTP message bridge
symfony/routing                       v4.4.5     Symfony Routing Component
symfony/service-contracts             v1.1.8     Generic abstractions related to writing services
symfony/translation                   v4.4.5     Symfony Translation Component
symfony/translation-contracts         v1.1.7     Generic abstractions related to translation
symfony/var-dumper                    v4.4.5     Symfony mechanism for exploring and dumping PHP variables
theseer/tokenizer                     1.1.3      A small library for converting tokenized PHP source co...
tijsverkoyen/css-to-inline-styles     2.2.2      CssToInlineStyles is a class that enables you to conve...
vlucas/phpdotenv                      v3.6.0     Loads environment variables from `.env` to `getenv()`,...
webmozart/assert                      1.7.0      Assertions to validate method input/output with nice e...
zendframework/zend-diactoros          1.8.7      PSR HTTP Message implementations
Post by aimeos » 11 Mar 2020, 13:52
Laravel 5.x has a bug that assigns parameters to empty route placeholders regardless of their name. That's fixed in Laravel 6+
Kaizer
Post by Kaizer » 11 Mar 2020, 14:40
I updated to Laravel 6 and it works indeed, thanks a lot !
I see 2 other issues:
- The stock status is not translated in the product details
- When I continue browsing, the language switches back to default
Post by aimeos » 11 Mar 2020, 15:01
Kaizer wrote: 11 Mar 2020, 14:40 - The stock status is not translated in the product details
That depends if there's a translation available for your language. If not, please add translations here for the "client" translation domain: https://www.transifex.com/aimeos/aimeos-core/
Until your translations get integrated into the next release, you can also add them locally:
https://aimeos.org/docs/Laravel/Overwrite_translations
Kaizer wrote: 11 Mar 2020, 14:40 - When I continue browsing, the language switches back to default
Adapt your route configuration so it contains the {locale} placeholder (and {currency} if needed)
Kaizer
Post by Kaizer » 11 Mar 2020, 15:26
- The translation already exists:
when displaying the page in english (2nd language on this site), the stock status is still displayed in french (default language)
- {locale} and {currency} are already defined in config/shop.php
Post by aimeos » 12 Mar 2020, 18:02
Guess, the locale parameter is missing here:
https://github.com/aimeos/ai-client-htm ... e.php#L130
Can you test if you add
... "s_prodcode" => $list->toArray(), 'locale' => $view->param( 'locale' ) ) ...
Probably the same there. Where exactly does that happen?
Kaizer
Post by Kaizer » 14 Mar 2020, 14:00
( I'm on Aimeos 2019.10 )
There is no " "s_prodcode" => $list->toArray()" in my file, only :
" array("s_prodcode" => $list ) " on this line
Nevertheless I added ", 'locale' => $view->param( 'locale' )" but the effects remain the same.
Language switching back to default happens for instance when using the "next" (or "previous") navigation link in the product detail page
Post by aimeos » 16 Mar 2020, 14:05
We've tried now several times to reproduce your behavior with several versions but are unable to get your result. If we add the locale selector like this:
	'routes' => [
		'account' => ['prefix' => '{locale}/myaccount', 'middleware' => ['web', 'auth']],
		'default' => ['prefix' => '{locale}/shop', 'middleware' => ['web']],
	'page' => [
		'account-index' => ['locale/select', 'account/profile', 'account/subscription', 'account/history', 'account/favorite', 'account/watch', 'basket/mini', 'catalog/session' ],
		'basket-index' => ['locale/select', 'basket/standard','basket/related' ],
		'catalog-count' => [ 'catalog/count' ],
		'catalog-detail' => ['locale/select', 'basket/mini','catalog/stage','catalog/detail','catalog/session' ],
		'catalog-list' => ['locale/select', 'basket/mini','catalog/filter','catalog/lists' ],
		'catalog-stock' => [ 'catalog/stock' ],
		'catalog-suggest' => [ 'catalog/suggest' ],
		'catalog-tree' => ['locale/select', 'basket/mini','catalog/filter','catalog/stage','catalog/lists' ],
		'checkout-confirm' => [ 'checkout/confirm' ],
		'checkout-index' => [ 'checkout/standard' ],
		'checkout-update' => [ 'checkout/update' ],
And e.g. in the catalog/list view:
@extends('shop::base')
@section('aimeos_header')
    <?= $aiheader['basket/mini'] ?>
    <?= $aiheader['catalog/filter'] ?>
    <?= $aiheader['catalog/lists'] ?>
    <?= $aiheader['locale/select'] ?>
@stop
@section('aimeos_head')
    <?= $aibody['locale/select'] ?>
    <?= $aibody['basket/mini'] ?>
@stop
@section('aimeos_nav')
    <?= $aibody['catalog/filter'] ?>
@stop
@section('aimeos_body')
     <?= $aibody['catalog/lists'] ?>
@stop
Then, the selected locale (language) is always used in the URLs (it don't gets lost) and the translation of the stock text is also in the correct language.
