Create new mshop table ?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 16 Mar 2020, 12:55
Versions of components:
aimeos/ai-admin-jqadm                 2019.10.6  Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm               2019.10.2  Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html                 2019.10.10 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi              2019.10.2  Aimeos JSON API extension
aimeos/ai-controller-frontend         2019.10.3  Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs             2019.10.4  Aimeos ai-controller-jobs extension
aimeos/ai-gettext                     2019.10.1  Aimeos Gettext extension
aimeos/ai-laravel                     2019.10.2  Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments                    2019.10.1  Payment extension for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer                 2019.10.1  SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core                    2019.10.7  Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel                 2019.10.1  Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
How to create new mshop table ?
I have added file /var/www/schmuck/ext/custom/lib/custom/setup/default/schema/page.php:
return [
    'table' => [
        'mshop_page' => function ( \Doctrine\DBAL\Schema\Schema $schema ) {
            $table = $schema->createTable( 'mshop_page' );
            $table->addColumn( 'id', 'integer', array( 'autoincrement' => true ) );
            $table->addColumn( 'siteid', 'integer', [] );
            $table->addColumn( 'type', 'string', array( 'length' => 64 ) );
            $table->addColumn( 'langid', 'string', array( 'length' => 5, 'notnull' => false ) );
            $table->addColumn( 'domain', 'string', array( 'length' => 32 ) );
            $table->addColumn( 'label', 'string', array( 'length' => 255 ) );
            $table->addColumn( 'content', 'text', array( 'length' => 0xffffff ) );
            $table->addColumn( 'status', 'smallint', [] );
            $table->addColumn( 'mtime', 'datetime', [] );
            $table->addColumn( 'ctime', 'datetime', [] );
            $table->addColumn( 'editor', 'string', array('length' => 255 ) );
            $table->setPrimaryKey( array( 'id' ), 'pk_mspag_id' );
            $table->addIndex( array( 'siteid', 'domain', 'status' ), 'idx_mspag_sid_domain_status' );
            $table->addIndex( array( 'siteid', 'domain', 'langid' ), 'idx_mspag_sid_domain_langid' );
            $table->addIndex( array( 'siteid', 'domain', 'label' ), 'idx_mspag_sid_dom_label' );
            return $schema;
But when I execute command
php artisan aimeos:setup
seems that migration even is not executed...
MikaelNazarenko
Expert
Re: Create new mshop table ?
Post by MikaelNazarenko » 16 Mar 2020, 15:42
I only found solution to add pages creation code to /var/www/schmuck/ext/labor/lib/custom/setup/default/schema/customer.php file, because I also have extended customer.
Then page table is created.. But doesn't look clear..
Post by aimeos » 17 Mar 2020, 08:28
The setup files are used by this setup task:
https://github.com/aimeos/aimeos-core/b ... eMShop.php
You should create your own setup task that extends from this task and overwrites the migrate() method.
