Multiple sites frontend Not displaying (only default site is displayed)
Hi, I created a multivendor shop with the Aimeos Laravel shop, however, only the default or rather the first site I created has its products displayed on the frontend. The other sites have the products being added to the products table but are not displayed. All the products have categories. I tried clearing cache and rebuilding the index and even resaving items in the sites but none of these options have helped in any way. What am I not doing right?
I'm using Laravel 6.18.6, php 7.4.3 and aimeos/aimeos-laravel: ~2020.04 on windows os
Re: Multiple sites frontend Not displaying (only default site is displayed)
Did you configure your routes for multiple shops?
https://aimeos.org/docs/Laravel/Configu ... iple_shops
Yes I configured. however, I noticed that the different shops were accessed from different URLs thus was able to access the sites eventually. Thank you
albcamargo61
Did you solve this issue? I have the same problem.
albcamargo61
Does any one have a solution? I'm stucked.
Can you please post your shop/config.php file (without credentials) and the output of "php artisan route:list"?
albcamargo61
Thanks.
My env:
Linux version 4.15.0-101-generic (buildd@lgw01-amd64-003) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #102-Ubuntu
PHP 7.2.24-0ubuntu0.18.04.4 (cli) (built: Apr 8 2020 15:45:57) ( NTS )
Laravel Framework 6.18.14
URL: biioh.co
My shop.php
<?php
return [
'apc_enabled' => false, // enable for maximum performance if APCu is availalbe
'apc_prefix' => 'aimeos:', // prefix for caching config and translation in APCu
'pcntl_max' => 4, // maximum number of parallel command line processes when starting jobs
'routes' => [
'jsonapi' => ['prefix' => 'colanta/jsonapi', 'middleware' => ['web', 'api']],
'account' => ['prefix' => 'colanta/profile', 'middleware' => ['web', 'auth']],
'colanta' => ['prefix' => 'colanta', 'middleware' => ['web']],
'page' => [
'account-index' => [ 'account/profile','account/subscription','account/history','account/favorite','account/watch','basket/mini','catalog/session','locale/select' ],
'basket-index' => [ 'basket/bulk', 'basket/standard','basket/related' ],
'catalog-count' => [ 'catalog/count' ],
'catalog-detail' => [ 'basket/mini','catalog/stage','catalog/detail','catalog/session','locale/select' ],
'catalog-list' => [ 'basket/mini','catalog/filter','catalog/stage','catalog/lists','locale/select' ],
'catalog-stock' => [ 'catalog/stock' ],
'catalog-suggest' => [ 'catalog/suggest' ],
'catalog-tree' => [ 'basket/mini','catalog/filter','catalog/stage','catalog/lists' ],
'checkout-confirm' => [ 'checkout/confirm' ],
'checkout-index' => [ 'checkout/standard' ],
'checkout-update' => [ 'checkout/update' ],
'resource' => [
'db' => [
'adapter' => config('database.connections.mysql.driver', 'mysql'),
'host' => config('database.connections.mysql.host', '127.0.0.1'),
'port' => config('database.connections.mysql.port', '3306'),
'socket' => config('database.connections.mysql.unix_socket', ''),
'database' => config('database.connections.mysql.database', 'forge'),
'username' => config('database.connections.mysql.username', 'forge'),
'password' => config('database.connections.mysql.password', ''),
'stmt' => ["SET SESSION sort_buffer_size=2097144; SET NAMES 'utf8mb4'; SET SESSION sql_mode='ANSI'"],
'limit' => 3, // maximum number of concurrent database connections
'defaultTableOptions' => [
'charset' => config('database.connections.mysql.charset'),
'collate' => config('database.connections.mysql.collation'),
//acamargo
//To show products from all sites in the frontend, you have to add this to your Laravel ./config/shop.php:
'frontend' => array(
'mshop' => array(
'common' => array(
'manager' => array(
'sitecheck' => 0
'admin' => [],
'client' => [
'html' => [
'basket' => [
'cache' => [
// 'enable' => false, // Disable basket content caching for development
'catalog' => [
'selection' => [
'type' => [
'color' => 'radio',
'length' => 'radio',
'width' => 'radio',
'controller' => [
'i18n' => [
'madmin' => [
'cache' => [
'manager' => [
// 'name' => 'None', // Disable caching for development
'log' => [
'manager' => [
'standard' => [
// 'loglevel' => 7, // Enable debug logging into madmin_log table
'mshop' => [
'command' => [
'frontend' => [
'backend' => [
And the output of "php artisan route:list"
| Domain | Method | URI | Name | Action | Middleware |
| | GET|HEAD | / | | Closure | web |
| | GET|HEAD | admin | aimeos_shop_admin | Aimeos\Shop\Controller\AdminController@indexAction | web |
| | GET|POST|HEAD | admin/{site}/jqadm/copy/{resource}/{id} | aimeos_shop_jqadm_copy | Aimeos\Shop\Controller\JqadmController@copyAction | web,auth |
| | GET|POST|HEAD | admin/{site}/jqadm/create/{resource} | aimeos_shop_jqadm_create | Aimeos\Shop\Controller\JqadmController@createAction | web,auth |
| | GET|POST|HEAD | admin/{site}/jqadm/delete/{resource}/{id?} | aimeos_shop_jqadm_delete | Aimeos\Shop\Controller\JqadmController@deleteAction | web,auth |
| | GET|POST|HEAD | admin/{site}/jqadm/export/{resource} | aimeos_shop_jqadm_export | Aimeos\Shop\Controller\JqadmController@exportAction | web,auth |
| | GET|HEAD | admin/{site}/jqadm/file/{type} | aimeos_shop_jqadm_file | Aimeos\Shop\Controller\JqadmController@fileAction | web,auth |
| | GET|HEAD | admin/{site}/jqadm/get/{resource}/{id} | aimeos_shop_jqadm_get | Aimeos\Shop\Controller\JqadmController@getAction | web,auth |
| | POST | admin/{site}/jqadm/save/{resource} | aimeos_shop_jqadm_save | Aimeos\Shop\Controller\JqadmController@saveAction | web,auth |
| | GET|POST|HEAD | admin/{site}/jqadm/search/{resource} | aimeos_shop_jqadm_search | Aimeos\Shop\Controller\JqadmController@searchAction | web,auth |
| | OPTIONS | admin/{site}/jsonadm/{resource?} | aimeos_shop_jsonadm_options | Aimeos\Shop\Controller\JsonadmController@optionsAction | web,auth |
| | PUT | admin/{site}/jsonadm/{resource}/{id?} | aimeos_shop_jsonadm_put | Aimeos\Shop\Controller\JsonadmController@putAction | web,auth |
| | POST | admin/{site}/jsonadm/{resource}/{id?} | aimeos_shop_jsonadm_post | Aimeos\Shop\Controller\JsonadmController@postAction | web,auth |
| | PATCH | admin/{site}/jsonadm/{resource}/{id?} | aimeos_shop_jsonadm_patch | Aimeos\Shop\Controller\JsonadmController@patchAction | web,auth |
| | GET|HEAD | admin/{site}/jsonadm/{resource}/{id?} | aimeos_shop_jsonadm_get | Aimeos\Shop\Controller\JsonadmController@getAction | web,auth |
| | DELETE | admin/{site}/jsonadm/{resource}/{id?} | aimeos_shop_jsonadm_delete | Aimeos\Shop\Controller\JsonadmController@deleteAction | web,auth |
| | GET|HEAD | api/user | | Closure | api,auth:api |
| | OPTIONS | colanta/jsonapi/{resource?} | aimeos_shop_jsonapi_options | Aimeos\Shop\Controller\JsonapiController@optionsAction | web,api |
| | DELETE | colanta/jsonapi/{resource} | aimeos_shop_jsonapi_delete | Aimeos\Shop\Controller\JsonapiController@deleteAction | web,api |
| | GET|HEAD | colanta/jsonapi/{resource} | aimeos_shop_jsonapi_get | Aimeos\Shop\Controller\JsonapiController@getAction | web,api |
| | POST | colanta/jsonapi/{resource} | aimeos_shop_jsonapi_post | Aimeos\Shop\Controller\JsonapiController@postAction | web,api |
| | PUT | colanta/jsonapi/{resource} | aimeos_shop_jsonapi_put | Aimeos\Shop\Controller\JsonapiController@putAction | web,api |
| | PATCH | colanta/jsonapi/{resource} | aimeos_shop_jsonapi_patch | Aimeos\Shop\Controller\JsonapiController@patchAction | web,api |
| | GET|POST|HEAD | colanta/profile | aimeos_shop_account | Aimeos\Shop\Controller\AccountController@indexAction | web,auth |
| | GET|POST|HEAD | colanta/profile/download/{dl_id} | aimeos_shop_account_download | Aimeos\Shop\Controller\AccountController@downloadAction | web,auth |
| | GET|POST|HEAD | colanta/profile/favorite/{fav_action?}/{fav_id?}/{d_name?}/{d_pos?} | aimeos_shop_account_favorite | Aimeos\Shop\Controller\AccountController@indexAction | web,auth |
| | GET|POST|HEAD | colanta/profile/watch/{wat_action?}/{wat_id?}/{d_name?}/{d_pos?} | aimeos_shop_account_watch | Aimeos\Shop\Controller\AccountController@indexAction | web,auth |
| | GET|HEAD | home | home | App\Http\Controllers\HomeController@index | web,auth |
| | GET|HEAD | login | login | App\Http\Controllers\Auth\LoginController@showLoginForm | web,guest |
| | POST | login | | App\Http\Controllers\Auth\LoginController@login | web,guest |
| | POST | logout | logout | App\Http\Controllers\Auth\LoginController@logout | web |
| | POST | password/confirm | | App\Http\Controllers\Auth\ConfirmPasswordController@confirm | web,auth |
| | GET|HEAD | password/confirm | password.confirm | App\Http\Controllers\Auth\ConfirmPasswordController@showConfirmForm | web,auth |
| | POST | password/email | password.email | App\Http\Controllers\Auth\ForgotPasswordController@sendResetLinkEmail | web |
| | POST | password/reset | password.update | App\Http\Controllers\Auth\ResetPasswordController@reset | web |
| | GET|HEAD | password/reset | password.request | App\Http\Controllers\Auth\ForgotPasswordController@showLinkRequestForm | web |
| | GET|HEAD | password/reset/{token} | password.reset | App\Http\Controllers\Auth\ResetPasswordController@showResetForm | web |
| | GET|HEAD | privacy | aimeos_shop_privacy | Aimeos\Shop\Controller\PageController@privacyAction | |
| | POST | register | | App\Http\Controllers\Auth\RegisterController@register | web,guest |
| | GET|HEAD | register | register | App\Http\Controllers\Auth\RegisterController@showRegistrationForm | web,guest |
| | GET|POST|HEAD | shop | aimeos_shop_list | Aimeos\Shop\Controller\CatalogController@listAction | web |
| | GET|POST|HEAD | shop/basket | aimeos_shop_basket | Aimeos\Shop\Controller\BasketController@indexAction | web |
| | GET|POST|HEAD | shop/checkout/{c_step?} | aimeos_shop_checkout | Aimeos\Shop\Controller\CheckoutController@indexAction | web |
| | GET|POST|HEAD | shop/confirm/{code?} | aimeos_shop_confirm | Aimeos\Shop\Controller\CheckoutController@confirmAction | web |
| | GET|POST|HEAD | shop/count | aimeos_shop_count | Aimeos\Shop\Controller\CatalogController@countAction | web |
| | GET|POST|HEAD | shop/pin/{pin_action}/{pin_id}/{d_name} | aimeos_shop_session_pinned | Aimeos\Shop\Controller\CatalogController@detailAction | web |
| | GET|POST|HEAD | shop/stock | aimeos_shop_stock | Aimeos\Shop\Controller\CatalogController@stockAction | web |
| | GET|POST|HEAD | shop/suggest | aimeos_shop_suggest | Aimeos\Shop\Controller\CatalogController@suggestAction | web |
| | GET|POST|HEAD | shop/{d_name}/{d_pos?}/{d_prodid?} | aimeos_shop_detail | Aimeos\Shop\Controller\CatalogController@detailAction | web |
| | GET|POST|HEAD | shop/{f_name}~{f_catid} | aimeos_shop_tree | Aimeos\Shop\Controller\CatalogController@treeAction | web |
| | GET|HEAD | terms | aimeos_shop_terms | Aimeos\Shop\Controller\PageController@termsAction | |
| | GET|POST|HEAD | update | aimeos_shop_update | Aimeos\Shop\Controller\CheckoutController@updateAction | |
My env:
URL: biioh.co
My shop.php
<?php
return [
'routes' => [
'page' => [
'resource' => [
'db' => [
//acamargo
'mshop' => array(
'common' => array(
'manager' => array(
'sitecheck' => 0
'admin' => [],
'client' => [
'html' => [
'basket' => [
'cache' => [
'catalog' => [
'selection' => [
'type' => [
'color' => 'radio',
'width' => 'radio',
'controller' => [
'i18n' => [
'madmin' => [
'cache' => [
'manager' => [
'log' => [
'manager' => [
'standard' => [
'mshop' => [
'command' => [
'frontend' => [
'backend' => [
You don't have your installation configured for multiple sites:
Your "routes" section in your ./config/shop.php file must at least look like:
'routes' => [
'jsonapi' => ['prefix' => '{site}/jsonapi', 'middleware' => ['web', 'api']],
'account' => ['prefix' => '{site}/profile', 'middleware' => ['web', 'auth']],
'default' => ['prefix' => '{site}/shop', 'middleware' => ['web']]
Dear aimeos team, would you care to ellaborate please?
If you add a couple of sites using the command:
how do you actually map "siteone" to its domain (i.e. www.myfirstdomain.mine)
and "sitetwo" to its domain (i.e. www.myseconddomain.mine)
So whenever you access myfirstdomain.mine you are displayed the home page of the siteone site and the sitetwo homepage when you navigate from myseconddomain.mine. (For the visitor would be as if they were two separate independant installations).
php artisan aimeos:setup siteone
php artisan aimeos:setup sitetwo
aimeos wrote: ↑22 May 2020, 17:05 You don't have your installation configured for multiple sites:
Your "routes" section in your ./config/shop.php file must at least look like:Code: Select all
'routes' => [ 'jsonapi' => ['prefix' => '{site}/jsonapi', 'middleware' => ['web', 'api']], 'account' => ['prefix' => '{site}/profile', 'middleware' => ['web', 'auth']], 'default' => ['prefix' => '{site}/shop', 'middleware' => ['web']] ],
Please read this for domain or subdomain routing (at the end of the section):
https://aimeos.org/docs/latest/laravel/ ... he-routing
The site code must be the domain in that case, i.e.:
php artisan aimeos:setup www.myfirstdomain.mine
php artisan aimeos:setup www.myseconddomain.mine
