Image scaling one by one
tyteck
Post by tyteck » 28 Apr 2020, 12:22
Hello and thanks again for aimeos.
OS : Ubuntu 18.04
Laravel : 6
package : "aimeos/aimeos-laravel": "~2019.10",
You already helped me on unset catalog during import csv and it's working (thanks).
My problem now is to generate preview on demand.
I explain.
The shop I'm working on is importing products from many partners and frequently the product image is obtained with an additional query. Every time I process one partner I'm updating dozens/hundreds of product. Getting the picture during import would make it very long. So I create a big csv with products, then I'm creating a job to grab all the image from url later (with a job/queue).
One "this product has no cover yet" image is set meanwhile.
In the csv, I'm setting the final path of the media. Import is running fine.
What I would want is, once the image has been downloaded; generate the preview with a
artisan aimeos:jobs media/scale <PRODUCT>
Is it possible ? If yes, what is the best way to achieve this with aimeos ?
Re: Image scaling one by one
Post by aimeos » 29 Apr 2020, 09:22
You could overwrite the media processor and remove that line in your code:
https://github.com/aimeos/ai-controller ... #L178-L180
Configure your new media processor using:
controller/common/product/import/csv/processor/media/name = Myprocessor
