Import csv with supplier
tyteck
Post by tyteck » 28 Apr 2020, 14:51
Hello and thanks again for aimeos.
OS : Ubuntu 18.04
Laravel : 6
package : "aimeos/aimeos-laravel": "~2019.10",
In french we have a saying "never 2 without 3" so it is my third question (and the last I hope).
I search in your documentation without finding any way to set supplier during csv import.
I tried to add a column supplier.code in the mapping only to get a big red error.
Is there a way to set supplier code for products during csv import ?
Re: Import csv with supplier
Post by aimeos » 29 Apr 2020, 09:32
At the moment it's not supported to import suppliers in the product CSV file (categories are). You can implement a processor for suppliers in exactly the same way than for categories:
https://github.com/aimeos/ai-controller ... andard.php
Simply replace "catalog" by "supplier" and "Catalog" by "Supplier" (case sensitive). Then, your mapping will work.
If you do so, please create a pull request on Github because we would love to get that feature into the core :-)
tyteck
Post by tyteck » 29 Apr 2020, 12:08
I was not not sure about the process.
Thanks for your reply. :)
tyteck
Post by tyteck » 04 May 2020, 08:57
Hello there
I've "finished" the product/import/csv that take care of supplier.
I would like to know how I can submit it to you.
I followed https://aimeos.org/docs/Developers/Git_workflow it but not really sure.
I will submit it as it and let you come back to me.
I'm expecting a reject :)
Post by aimeos » 07 May 2020, 08:07
Have you already been able to improve your PR?
OscarMessinaJr
Post by OscarMessinaJr » 19 May 2020, 12:36
Any predictions when we should see this feature? It would be great to import products with supplier
Travin
Post by Travin » 18 Jun 2020, 06:16
aimeos wrote: 29 Apr 2020, 09:32 https://github.com/aimeos/ai-controller ... andard.php
It seems to me a little bit wrong, because of process method is not fully suitable for Supplier domain. Simple replacing is not working, I've tried now.
Also, as I see, we have to save supplier <-> product relation to table mshop_supplier_list, not at mshop_product_list despite of price <-> product and media <-> product relations, which store at mshop_product_list
Will do that today
Post by aimeos » 18 Jun 2020, 06:24
Exactly and the catalog importer for product CSV does the same for mshop_catalog_list instead of mshop_supplier_list
AndreyFedotov
Post by AndreyFedotov » 09 Mar 2021, 09:58
aimeos wrote: 29 Apr 2020, 09:32 At the moment it's not supported to import suppliers in the product CSV file (categories are). You can implement a processor for suppliers in exactly the same way than for categories:
Is there any update about this case? I need to import products and associate existed suppliers. There are only two possible values how can I do import?
Post by aimeos » 09 Mar 2021, 18:13
It's implemented and available. Here's the source code:
