Override SQL Querys for ai-laravel does not work
kn0x1c
Post by kn0x1c » 29 Apr 2020, 11:58
Hello there,
I'm really new to aimeos but I think it's a pretty nice shop system. Currently I'm facing a problem, where I want to override the SQL Querys for the customers, but it is still using the new from ai-laravel.
I already tried the suggestions from: laravel-package-f18/override-ext-ai-laravel-t1135.html
and also: help-f15/how-to-add-additional-fields-t ... -t599.html
What I've done:
Created a new folder in /ext with my custom name.
I tried adding the file mshop.php in the <<module_path>>/config folder, with the following content:
<?php
return array(
	'manager' => array(
		'address' => array(
			'laravel' => array(
				'delete' => array(
					'ansi' => '
						DELETE FROM "ASDFBREAK_address"
						WHERE :cond AND siteid = ?
				'insert' => array(
					'ansi' => '
						INSERT INTO "ASDFBREAK_address" ( :names
							"parentid", "company", "vatid", "salutation", "title",
							"firstname", "lastname", "address1", "address2", "address3",
							"postal", "city", "state", "countryid", "langid", "telephone",
							"email", "telefax", "website", "longitude", "latitude",
							"pos", "mtime", "editor", "siteid", "ctime"
						) VALUES ( :values
				'update' => array(
					'ansi' => '
						UPDATE "ASDFBREAK_address"
						SET :names
							"parentid" = ?, "company" = ?, "vatid" = ?, "salutation" = ?,
							"title" = ?, "firstname" = ?, "lastname" = ?, "address1" = ?,
							"address2" = ?, "address3" = ?, "postal" = ?, "city" = ?,
							"state" = ?, "countryid" = ?, "langid" = ?, "telephone" = ?,
							"email" = ?, "telefax" = ?, "website" = ?, "longitude" = ?, "latitude" = ?,
							"pos" = ?, "mtime" = ?, "editor" = ?, "siteid" = ?
						WHERE "id" = ?
				'search' => array(
					'ansi' => '
						SELECT DISTINCT :columns
							lvuad."id" AS "customer.address.id", lvuad."parentid" AS "customer.address.parentid",
							lvuad."company" AS "customer.address.company", lvuad."vatid" AS "customer.address.vatid",
							lvuad."salutation" AS "customer.address.salutation", lvuad."title" AS "customer.address.title",
							lvuad."firstname" AS "customer.address.firstname", lvuad."lastname" AS "customer.address.lastname",
							lvuad."address1" AS "customer.address.address1", lvuad."address2" AS "customer.address.address2",
							lvuad."address3" AS "customer.address.address3", lvuad."postal" AS "customer.address.postal",
							lvuad."city" AS "customer.address.city", lvuad."state" AS "customer.address.state",
							lvuad."countryid" AS "customer.address.countryid", lvuad."langid" AS "customer.address.languageid",
							lvuad."telephone" AS "customer.address.telephone", lvuad."email" AS "customer.address.email",
							lvuad."telefax" AS "customer.address.telefax", lvuad."website" AS "customer.address.website",
							lvuad."longitude" AS "customer.address.longitude", lvuad."latitude" AS "customer.address.latitude",
							lvuad."pos" AS "customer.address.position", lvuad."mtime" AS "customer.address.mtime",
							lvuad."editor" AS "customer.address.editor", lvuad."ctime" AS "customer.address.ctime",
							lvuad."siteid" AS "customer.address.siteid"
						FROM "ASDFBREAK_address" AS lvuad
						:joins
						WHERE :cond
						/*-orderby*/ ORDER BY :order /*orderby-*/
						LIMIT :size OFFSET :start
				'count' => array(
					'ansi' => '
						SELECT COUNT(*) AS "count"
						FROM (
							SELECT DISTINCT lvuad."id"
							:joins
							WHERE :cond
							LIMIT 10000 OFFSET 0
						) AS list
				'newid' => array(
					'db2' => 'SELECT IDENTITY_VAL_LOCAL()',
					'mysql' => 'SELECT LAST_INSERT_ID()',
					'oracle' => 'SELECT ASDFBREAK_address.CURRVAL FROM DUAL',
					'pgsql' => 'SELECT lastval()',
					'sqlite' => 'SELECT last_insert_rowid()',
					'sqlsrv' => 'SELECT SCOPE_IDENTITY()',
					'sqlanywhere' => 'SELECT @@IDENTITY',
		'lists' => array(
			'type' => array(
				'laravel' => array(
					'insert' => array(
						'ansi' => '
							INSERT INTO "ASDFBREAK_list_type" ( :names
								"code", "domain", "label", "pos", "status",
							) VALUES ( :values
					'update' => array(
						'ansi' => '
							UPDATE "ASDFBREAK_list_type"
							SET :names
								"code" = ?, "domain" = ?, "label" = ?, "pos" = ?,
								"status" = ?, "mtime" = ?, "editor" = ?
							WHERE "siteid" = ? AND "id" = ?
					'delete' => array(
						'ansi' => '
							DELETE FROM "ASDFBREAK_list_type"
					'search' => array(
						'ansi' => '
								lvulity."id" AS "customer.lists.type.id", lvulity."siteid" AS "customer.lists.type.siteid",
								lvulity."code" AS "customer.lists.type.code", lvulity."domain" AS "customer.lists.type.domain",
								lvulity."label" AS "customer.lists.type.label", lvulity."status" AS "customer.lists.type.status",
								lvulity."mtime" AS "customer.lists.type.mtime", lvulity."editor" AS "customer.lists.type.editor",
								lvulity."ctime" AS "customer.lists.type.ctime", lvulity."pos" AS "customer.lists.type.position"
							FROM "ASDFBREAK_list_type" AS lvulity
							:joins
							WHERE :cond
					'count' => array(
						'ansi' => '
							FROM (
								SELECT DISTINCT lvulity."id"
								:joins
								WHERE :cond
							) AS LIST
					'newid' => array(
						'oracle' => 'SELECT ASDFBREAK_list_type.CURRVAL FROM DUAL',
			'laravel' => array(
				'aggregate' => array(
					'ansi' => '
						SELECT "key", COUNT(DISTINCT "id") AS "count"
						FROM (
							SELECT :key AS "key", lvuli."id" AS "id"
							FROM "ASDFBREAK_list" AS lvuli
							:joins
							WHERE :cond
						) AS list
						GROUP BY "key"
				'delete' => array(
					'ansi' => '
						DELETE FROM "ASDFBREAK_list"
				'insert' => array(
					'ansi' => '
						INSERT INTO "ASDFBREAK_list" ( :names
							"parentid", "key", "type", "domain", "refid", "start", "end",
						"config", "pos", "status", "mtime", "editor", "siteid", "ctime"
						) VALUES ( :values
				'update' => array(
					'ansi' => '
						UPDATE "ASDFBREAK_list"
						SET :names
							"parentid"=?, "key" = ?, "type" = ?, "domain" = ?, "refid" = ?, "start" = ?,
							"end" = ?, "config" = ?, "pos" = ?, "status" = ?, "mtime" = ?, "editor" = ?
				'search' => array(
					'ansi' => '
						SELECT :columns
							lvuli."id" AS "customer.lists.id", lvuli."siteid" AS "customer.lists.siteid",
							lvuli."parentid" AS "customer.lists.parentid", lvuli."type" AS "customer.lists.type",
							lvuli."domain" AS "customer.lists.domain", lvuli."refid" AS "customer.lists.refid",
							lvuli."start" AS "customer.lists.datestart", lvuli."end" AS "customer.lists.dateend",
							lvuli."config" AS "customer.lists.config", lvuli."pos" AS "customer.lists.position",
							lvuli."status" AS "customer.lists.status", lvuli."mtime" AS "customer.lists.mtime",
							lvuli."editor" AS "customer.lists.editor", lvuli."ctime" AS "customer.lists.ctime"
						:joins
						WHERE :cond
						GROUP BY :columns
							lvuli."id", lvuli."parentid", lvuli."siteid", lvuli."type",
							lvuli."domain", lvuli."refid", lvuli."start", lvuli."end",
							lvuli."config", lvuli."pos", lvuli."status", lvuli."mtime",
							lvuli."editor", lvuli."ctime"
				'count' => array(
					'ansi' => '
						FROM (
							SELECT DISTINCT lvuli."id"
							:joins
							WHERE :cond
						) AS list
				'newid' => array(
					'oracle' => 'SELECT ASDFBREAK_list.CURRVAL FROM DUAL',
		'property' => array(
			'type' => array(
				'laravel' => array(
					'delete' => array(
						'ansi' => '
							DELETE FROM "ASDFBREAK_property_type"
					'insert' => array(
						'ansi' => '
							INSERT INTO "ASDFBREAK_property_type" ( :names
							) VALUES ( :values
					'update' => array(
						'ansi' => '
							UPDATE "ASDFBREAK_property_type"
							SET :names
					'search' => array(
						'ansi' => '
								lvuprty."id" AS "customer.property.type.id", lvuprty."siteid" AS "customer.property.type.siteid",
								lvuprty."code" AS "customer.property.type.code", lvuprty."domain" AS "customer.property.type.domain",
								lvuprty."label" AS "customer.property.type.label", lvuprty."status" AS "customer.property.type.status",
								lvuprty."mtime" AS "customer.property.type.mtime", lvuprty."editor" AS "customer.property.type.editor",
								lvuprty."ctime" AS "customer.property.type.ctime", lvuprty."pos" AS "customer.property.type.position"
							FROM "ASDFBREAK_property_type" lvuprty
							:joins
							WHERE :cond
					'count' => array(
						'ansi' => '
							FROM (
								SELECT DISTINCT lvuprty."id"
								:joins
								WHERE :cond
							) AS list
					'newid' => array(
						'oracle' => 'SELECT ASDFBREAK_property_type_seq.CURRVAL FROM DUAL',
			'laravel' => array(
				'delete' => array(
					'ansi' => '
						DELETE FROM "ASDFBREAK_property"
		'laravel' => array(
			'delete' => array(
				'ansi' => '
					DELETE FROM "ASDFBREAK"
					WHERE :cond
			'insert' => array(
				'ansi' => '
					INSERT INTO "ASDFBREAK" ( :names
						"siteid", "name", "email", "company", "vatid", "salutation", "title",
						"birthday", "status", "vdate", "password",
						"updated_at", "editor", "created_at"
					) VALUES ( :values
			'update' => array(
				'ansi' => '
					UPDATE "ASDFBREAK"
					SET :names
						"siteid" = ?, "name" = ?, "email" = ?, "company" = ?, "vatid" = ?,
						"salutation" = ?, "title" = ?, "firstname" = ?, "lastname" = ?,
						"address1" = ?, "address2" = ?, "address3" = ?, "postal" = ?,
						"city" = ?, "state" = ?, "countryid" = ?, "langid" = ?,
						"telephone" = ?, "telefax" = ?, "website" = ?,
						"longitude" = ?, "latitude" = ?, "birthday" = ?,
						"status" = ?, "vdate" = ?, "password" = ?, "updated_at" = ?, "editor" = ?
					WHERE "id" = ?
			'search' => array(
				'ansi' => '
						lvu."id" AS "customer.id", lvu."siteid" AS "customer.siteid",
						lvu."name" AS "customer.label", lvu."email" AS "customer.code",
						lvu."company" AS "customer.company", lvu."vatid" AS "customer.vatid",
						lvu."salutation" AS "customer.salutation", lvu."title" AS "customer.title",
						lvu."firstname" AS "customer.firstname", lvu."lastname" AS "customer.lastname",
						lvu."address1" AS "customer.address1", lvu."address2" AS "customer.address2",
						lvu."address3" AS "customer.address3", lvu."postal" AS "customer.postal",
						lvu."city" AS "customer.city", lvu."state" AS "customer.state",
						lvu."countryid" AS "customer.countryid", lvu."langid" AS "customer.languageid",
						lvu."telephone" AS "customer.telephone",lvu."telefax" AS "customer.telefax",
						lvu."email" AS "customer.email", lvu."website" AS "customer.website",
						lvu."longitude" AS "customer.longitude", lvu."latitude" AS "customer.latitude",
						lvu."birthday" AS "customer.birthday", lvu."status" AS "customer.status",
						lvu."vdate" AS "customer.dateverified", lvu."password" AS "customer.password",
						lvu."created_at" AS "customer.ctime", lvu."updated_at" AS "customer.mtime",
						lvu."editor" AS "customer.editor"
					FROM "ASDFBREAK" AS lvu
					:joins
					WHERE :cond
			'count' => array(
				'ansi' => '
					FROM (
						SELECT DISTINCT lvu."id"
						:joins
						WHERE :cond
					) AS list
			'newid' => array(
				'oracle' => 'SELECT ASDFBREAK.CURRVAL FROM DUAL',
I tried adding a file in <<module path>>/lib/custom/config/mshop/customer.php with the following content:
<?php
return array(
		'manager' => array(
			'address' => array(
				'laravel' => array(
					'delete' => array(
						'ansi' => '
							DELETE FROM "ASDF_address"
					'insert' => array(
						'ansi' => '
							INSERT INTO "ASDF_address" ( :names
							) VALUES ( :values
						'search' => array(
							'ansi' => '
								FROM "ASDF_list_type" AS lvulity
								:joins
								WHERE :cond
						'count' => array(
							'ansi' => '
								FROM (
									:joins
									WHERE :cond
								) AS LIST
						'newid' => array(
							'oracle' => 'SELECT ASDF_list_type.CURRVAL FROM DUAL',
				'laravel' => array(
						'ansi' => '
							FROM (
								FROM "ASDF_list" AS lvuli
								:joins
								WHERE :cond
							) AS list
							GROUP BY "key"
					'delete' => array(
						'ansi' => '
							DELETE FROM "ASDF_list"
					'insert' => array(
						'ansi' => '
							INSERT INTO "ASDF_list" ( :names
							) VALUES ( :values
					'update' => array(
						'ansi' => '
							UPDATE "ASDF_list"
							SET :names
					'search' => array(
						'ansi' => '
							SELECT :columns
							:joins
							WHERE :cond
							GROUP BY :columns
					'count' => array(
						'ansi' => '
							FROM (
								:joins
								WHERE :cond
							) AS list
					'newid' => array(
						'oracle' => 'SELECT ASDF_list.CURRVAL FROM DUAL',
				'type' => array(
					'laravel' => array(
						'delete' => array(
							'ansi' => '
								DELETE FROM "ASDF_property_type"
						'insert' => array(
							'ansi' => '
								INSERT INTO "ASDF_property_type" ( :names
								) VALUES ( :values
						'update' => array(
							'ansi' => '
								UPDATE "ASDF_property_type"
								SET :names
						'search' => array(
							'ansi' => '
								FROM "ASDF_property_type" lvuprty
								:joins
								WHERE :cond
						'count' => array(
							'ansi' => '
								FROM (
									:joins
									WHERE :cond
								) AS list
						'newid' => array(
							'oracle' => 'SELECT ASDF_property_type_seq.CURRVAL FROM DUAL',
				'laravel' => array(
					'delete' => array(
						'ansi' => '
							DELETE FROM "ASDF_property"
					'insert' => array(
						'ansi' => '
							INSERT INTO "ASDF_property" ( :names
								"parentid", "key", "type", "langid", "value",
							) VALUES ( :values
					'update' => array(
						'ansi' => '
							UPDATE "ASDF_property"
							SET :names
								"parentid" = ?, "key" = ?, "type" = ?, "langid" = ?,
								"value" = ?, "mtime" = ?, "editor" = ?
					'search' => array(
						'ansi' => '
								lvupr."id" AS "customer.property.id", lvupr."parentid" AS "customer.property.parentid",
								lvupr."siteid" AS "customer.property.siteid", lvupr."type" AS "customer.property.type",
								lvupr."langid" AS "customer.property.languageid", lvupr."value" AS "customer.property.value",
								lvupr."mtime" AS "customer.property.mtime", lvupr."editor" AS "customer.property.editor",
								lvupr."ctime" AS "customer.property.ctime"
							FROM "ASDF_property" AS lvupr
							:joins
							WHERE :cond
					'count' => array(
						'ansi' => '
							FROM (
								SELECT DISTINCT lvupr."id"
								:joins
								WHERE :cond
							) AS list
					'newid' => array(
						'oracle' => 'SELECT ASDF_property_seq.CURRVAL FROM DUAL',
			'laravel' => array(
				'delete' => array(
					'ansi' => '
						DELETE FROM "ASDF"
						WHERE :cond
				'insert' => array(
					'ansi' => '
						INSERT INTO "ASDF" ( :names
						) VALUES ( :values
				'update' => array(
					'ansi' => '
						UPDATE "ASDF"
						SET :names
						WHERE "id" = ?
				'search' => array(
					'ansi' => '
						:joins
						WHERE :cond
				'count' => array(
					'ansi' => '
						FROM (
							FROM "ASDF" AS lvu
							:joins
							WHERE :cond
						) AS list
				'newid' => array(
					'oracle' => 'SELECT ASDF.CURRVAL FROM DUAL',
I tried adding a file in the <<module path>>/lib/custom/config/mshop.php with the following content:
<?php
 * @copyright Aimeos (aimeos.org), 2015-2018
return array(
		'manager' => array(
			'address' => array(
				'laravel' => array(
					'delete' => array(
						'ansi' => '
					'insert' => array(
						'ansi' => '
							) VALUES ( :values
					'update' => array(
						'ansi' => '
							UPDATE "ASDF_address"
							SET :names
							WHERE "id" = ?
					'search' => array(
						'ansi' => '
							FROM "ASDF_address" AS lvuad
							:joins
							WHERE :cond
					'count' => array(
						'ansi' => '
							FROM (
								:joins
								WHERE :cond
							) AS list
					'newid' => array(
						'oracle' => 'SELECT ASDF_address.CURRVAL FROM DUAL',
			'lists' => array(
				'type' => array(
					'laravel' => array(
						'insert' => array(
							'ansi' => '
								INSERT INTO "ASDF_list_type" ( :names
								) VALUES ( :values
						'update' => array(
							'ansi' => '
								UPDATE "ASDF_list_type"
								SET :names
						'delete' => array(
							'ansi' => '
								DELETE FROM "ASDF_list_type"
						'search' => array(
							'ansi' => '
								:joins
								WHERE :cond
						'count' => array(
							'ansi' => '
								FROM (
									:joins
									WHERE :cond
								) AS LIST
						'newid' => array(
				'laravel' => array(
						'ansi' => '
							FROM (
								:joins
								WHERE :cond
							) AS list
							GROUP BY "key"
					'delete' => array(
						'ansi' => '
					'insert' => array(
						'ansi' => '
							) VALUES ( :values
					'update' => array(
						'ansi' => '
							UPDATE "ASDF_list"
							SET :names
					'search' => array(
						'ansi' => '
							SELECT :columns
							:joins
							WHERE :cond
							GROUP BY :columns
					'count' => array(
						'ansi' => '
							FROM (
								:joins
								WHERE :cond
							) AS list
					'newid' => array(
				'type' => array(
					'laravel' => array(
						'delete' => array(
							'ansi' => '
						'insert' => array(
							'ansi' => '
								) VALUES ( :values
						'update' => array(
							'ansi' => '
								SET :names
						'search' => array(
							'ansi' => '
								:joins
								WHERE :cond
						'count' => array(
							'ansi' => '
								FROM (
									:joins
									WHERE :cond
								) AS list
						'newid' => array(
				'laravel' => array(
					'delete' => array(
						'ansi' => '
					'insert' => array(
						'ansi' => '
							) VALUES ( :values
					'update' => array(
						'ansi' => '
							SET :names
					'search' => array(
						'ansi' => '
							:joins
							WHERE :cond
					'count' => array(
						'ansi' => '
							FROM (
								:joins
								WHERE :cond
							) AS list
					'newid' => array(
			'laravel' => array(
				'delete' => array(
					'ansi' => '
						DELETE FROM "ASDF"
						WHERE :cond
				'insert' => array(
					'ansi' => '
						) VALUES ( :values
				'update' => array(
					'ansi' => '
						UPDATE "ASDF"
						SET :names
						WHERE "id" = ?
				'search' => array(
					'ansi' => '
						:joins
						WHERE :cond
				'count' => array(
					'ansi' => '
						FROM (
							FROM "ASDF" AS lvu
							:joins
							WHERE :cond
						) AS list
				'newid' => array(
I already created the composer.json
	"name": "custom",
	"description": "Customization for database",
	"keywords": ["custom", "adapter", "laravel", "shop", "e-commerce"],
	"type": "aimeos-extension",
	"license": "None",
	"minimum-stability": "dev",
	"prefer-stable": true,
	"require": {
		"php": ">=5.5.0",
		"composer/installers": "^1.0",
		"laravel/framework": "~5.0||~6.0||~7.0",
		"zendframework/zend-diactoros": "~1.0",
		"aimeos/aimeos-core": "2019.10.*"
	"autoload": {
		"classmap": [
            "ext/<<module path>>/lib/custom/src",
            "ext/<<module path>>/controller/common/src",
            "ext/<<module path>>/controller/frontend/src",
            "ext/<<module path>>/controller/jobs/src",
            "ext/<<module path>>/client/html/src",
            "ext/<<module path>>/client/jsonapi/src",
            "ext/<<module path>>/admin/html/src",
            "ext/<<module path>>/admin/jsonadm/src"
and manifest.php:
<?php
return array(
	'name' => 'ifta-custom',
	'depends' => array(
		'aimeos-core',
		'ai-admin-extadm',
		'ai-admin-jqadm',
		'ai-admin-jsonadm',
		'ai-client-html',
		'ai-client-jsonapi',
		'ai-controller-jobs',
		'ai-laravel',
Sadly it does not work at all. When I run the composer, it didn't even mention my new module (should it?):
<?php
return array(
	'depends' => array(
		'aimeos-core',
		'ai-admin-extadm',
		'ai-admin-jqadm',
		'ai-admin-jsonadm',
		'ai-client-html',
		'ai-laravel',
I'm using laravel 7, aimeos 2019.10, and PHP7 and working on MacOS Catalina
kn0x1c
Re: Override SQL Querys for ai-laravel does not work
Post by kn0x1c » 30 Apr 2020, 07:37
Hello again,
I'm currently trying to implement this shop for a customer of me, so I would really appreciate some help, since every post in this forum was already solved/answered except mine :(
Thanks in advance!
Post by aimeos » 01 May 2020, 07:21
If you need a solution within a short period of time, pay the Aimeos company for help:
https://aimeos.com/support#c411
In the forum, we all help others in our spare time.
Placing the file in ./lib/custom/config/ won't work as long as that directory isn't listed in the "config" section of the manifest.php and in your ./config/mshop.php file you've missed the "customer" key:
return [
	'customer' => [
		'manager' => [
kn0x1c
Post by kn0x1c » 02 May 2020, 10:18
Hey there,
thank you very much, I tried it today and it worked like a charm. Sorry for my inappropriate word in the last post, I didn't know you are doing this in your spare time and I was really frustated on this days.
I looked up the subscription and told my customer about this, but he refused to buy this, so I won't be able to buy a premium subscription here, but I will appreciate you work here much more in the future, since I know you are doing this in your spare time.
Is there anything left todo, like close this thread or something like that? My problem is solved perfectly!
