admin customer table: define default sorting / order
columbo
Post by columbo » 14 May 2020, 15:08
I added some additional fields to my default customer table, like:
'customer' => [
	'fields' => array( 'customer.status', 'customer.code', 'customer.lastname', 'customer.company', 'customer.city', 'customer.ctime' ),
It works fine, but how can I define a default sorting?
e.g. all customers should be ordered / sorted by customer.ctime ASC
Re: admin customer table: define default sorting / order
Post by aimeos » 14 May 2020, 15:16
Changing the default sorting without user interaction is only possible if you overwrite the JQAdm customer class and add a sorting before initCriteria() here: https://github.com/aimeos/ai-admin-jqad ... d.php#L248
