CSS3 variables in 2020.04
nunomira
Post by nunomira » 26 May 2020, 17:09
I have just installed Aimeos 2020.04 using
composer create-project aimeos/aimeos myshop
and tried the CSS example
aimeos {
  --ai-primary: #FFA840;
  --ai-primary-light: #FFB850;
  --ai-secondary: #555;
  --ai-light: #D0D0D0;
  --ai-bg: #FFF;
mentioned in the announcement but nothing happens.
I've added this CSS code to myfile.css and added it to the app.blade.php, before the theme's css.
What am I missing?
Re: CSS3 variables in 2020.04
Post by aimeos » 27 May 2020, 15:51
You forgot the dot before the "aimeos" CSS class. Use:
.aimeos {
  --ai-bg: #FFF;
nunomira
Post by nunomira » 27 May 2020, 18:54
Thanks!
First I felt really stupid for not being able to copy-paste the code correctly.
But now that I've corrected the code, it still doesn't work.
I tried
.aimeos {
  --ai-primary: #FF0000;
  --ai-primary-light: #FF0000;
  --ai-secondary: #FF0000;
  --ai-light: #FF0000;
  --ai-bg: #FF0000;
But nothing changes.
I looked at
/packages/aimeos/shop/themes/elegance/aimeos.css
but there are no references to any of these variables.
So, there is something I'm still missing completely.
Post by aimeos » 28 May 2020, 09:06
Did you update your installation? Then you have to publish the new CSS files first using:
php artisan vendor:publish --all
nunomira
Post by nunomira » 28 May 2020, 09:35
Hi!
Thanks.
No, I didn't do anything like that.
I thought I had to create a CSS file with that code and simply add it the app.blade.php, before the theme's CSS.
But now I have tried
[/code]php artisan vendor:publish --all[/code]
but still nothing happens.
What do you mean by updating my installation?
I run
And now I have tried
composer update
What am I missing?
Post by aimeos » 28 May 2020, 09:41
Sorry, the aimeos/aimeos distribution is still using 2019.10 LTS. You have to use
composer create-project laravel/laravel:~6.0
composer require aimeos/aimeos-laravel:~2020.04
and perform the installation of the Aimeos package manually to use the latest release:
https://github.com/aimeos/aimeos-larave ... of-content
nunomira
Post by nunomira » 28 May 2020, 10:32
Now it's working, thanks!
I could have looked at composer.json and see I wan't on 2020.04!
:lol:
