Change Password
nunomira
Change Password
Post by nunomira » 26 May 2020, 17:44
I have just installed Aimeos 2020.04 using
composer create-project aimeos/aimeos myshop
on Homestead
Is there a screen to change the password for the User? And for the Admin?
Or is something that I have to implement myself?
I'm familiar with Laravel, so no problem. Just curious!
:D
Re: Change Password
Post by aimeos » 27 May 2020, 15:53
Laravel contains a "login", "registration" and "password forgotten" form but none "password change" AFAIK, so you have to implement it yourself. The password for the admin can be changed too when you implement the form because both are stored in the "users" table.
nunomira
Re: Change Password
Post by nunomira » 27 May 2020, 18:45
Thanks!
