Edit sanitize method in vendor file
emdee
Post by emdee » 12 Jun 2020, 11:48
I need to overide method sanitize in \vendor\aimeos\aimeos-core\lib\mwlib\src\MW\Common\Base.php
What is the best practice to do that to avoid upgrade issues in the future ?
One similiar solution I made before:
When the product is saved in admin, it generates sanitized URL for url.segment. I was able to edit this function right in ext file :
ext/ai-laravel/lib/custom/src/MW/View/Helper/Url/Laravel5.php
I left there original function sanitize() added my own function sanitize2() and now original method calling my own function.
It is right to edit functions in ext folder like that ?
But now the problem is:
When product url.segment is empty, it is generated from product.label. And this logic is only in vendor files
as I wrote at the beginning. So what is the best practice to solve this problem please ?
Thank you
Laravel 7
Aimeos 2020.04
PHP 7.4
Xampp
Re: Edit sanitize method in vendor file
Post by aimeos » 13 Jun 2020, 17:03
The only way is to extend the classes and overwrite the methods where it's used.
Why do you want to change it?
emdee
Post by emdee » 15 Jun 2020, 12:01
Thanks for your response. So I can do it with service provider, as mentioned here ? https://laracasts.com/discuss/channels/ ... or-methods
I need to change it, because there are missing letters, when you write product label in Czech / Slovak language.
When you write a Czech/Slovak title of a product for example "Počítač ASUS" it generates url "po-ta-asus" instead of "pocitac-asus"
So I edited function sanitize() and now no character is missing, which is very desirable for SEO.
Post by aimeos » 15 Jun 2020, 17:36
In dev-master, we use that code:
https://github.com/aimeos/aimeos-core/b ... #L147-L148
Does this work for you (requires "voku/portable-ascii": "^1.4")?
If yes, it will be in the new release in three weeks. This is much easier than changing all occurrences the method is used in the code.
emdee
Post by emdee » 16 Jun 2020, 11:24
Yes it works, thanks. And in case of similiar problem in future, the best practice is to extend original class with service provider ?
If you publish new upgrade, only vendor files are changed or files in root folder (for example /ext/ folder) too ?
Post by aimeos » 16 Jun 2020, 11:39
emdee wrote: 16 Jun 2020, 11:24 Yes it works, thanks. And in case of similiar problem in future, the best practice is to extend original class with service provider ?
No, because it's not implemented as Laravel service provider which you can overwrite. It's only a class that's used.
emdee wrote: 16 Jun 2020, 11:24 If you publish new upgrade, only vendor files are changed or files in root folder (for example /ext/ folder) too ?
Yes
