Boolean attribute values
Ivan
Post by Ivan » 21 Jul 2020, 12:11
Hi, I can create attribute type. Than I can connect string value to attribute type.
But can I create attribute with bool value, like tags.
For example I have product with name: "honey". I need to add attribute: "is_natural" with some icon.
Is it possible to do in exists admin panel functionality?
Thank you!
Re: Boolean attribute values
Post by aimeos » 23 Jul 2020, 08:17
For a boolean value, you should add the "isnatural" attribute to the product or not. The attributes can contain images which you can display if the attribute is assigned to the product.
Ivan
Post by Ivan » 23 Jul 2020, 08:41
Thank you for reply
