Requirements for coupon code "fafafafa" aren't met
ryankim
Post by ryankim » 24 Jul 2020, 18:55
*Voucher: 3 - abcdqer (Default)*
Basic
- Status : Enabled
- Label : abcdqwer
- Provider : FixedRebate,Category,Required
Option Value
category.code WR100003
fixedrebate.productcode WR100003
fixedrebate.rebate {"USD":150}
required.productcode WR100003
Codes
Code Count
fafafafa 5
*Product: Warranty Large*
Basic
- Status : Enabled
- Type : Voucher
- SKU : WR100003
- Label : Warranty Large
I set up like this, but it doesn't work.
How to fix it?
Re: Requirements for coupon code "fafafafa" aren't met
Post by aimeos » 27 Jul 2020, 08:58
You've configured that your discount product must be already in the basket and this doesn't work.
Remove this configuration:
ryankim
Post by ryankim » 27 Jul 2020, 18:24
Thank you so much. It works!
