using selected lang and currency for custom page
bilginkilic
Post by bilginkilic » 18 Aug 2020, 13:54
how can we use aimeos framework capability of language support ( lang dictionary) on custom pages
@bilginkilic_ (twitter)
Re: using selected lang and currency for custom page
Post by aimeos » 19 Aug 2020, 07:37
Do you mean using translations? If yes, there's an aitranslate() view helper:
https://aimeos.org/docs/Laravel/Use_Bla ... figuration
bilginkilic
Post by bilginkilic » 26 Aug 2020, 07:50
https://prnt.sc/u61aud
We have designed something like this custom page. Product method can get language and currency parameters? or how can we use globalization features of aimeos? You may see our custom home page here: https://paltoru2.tulparstudyo.net/ You may see when we change language it does not affect our custom page but listing page.
<?php
namespace App\Http\Controllers;
use Illuminate\Http\Request;
use \Aimeos\Shop\Facades\Product;
use \Aimeos\Shop\Facades\Catalog;
use Aimeos\Shop\Facades\Shop;
use Illuminate\Routing\Controller;
use Illuminate\Support\Facades\Response;
class HomeController extends Controller
     * Create a new controller instance.
     * @return void
    public function __construct()
        // $this->middleware('auth');
     * Show the application dashboard.
     * @return \Illuminate\Contracts\Support\Renderable
    public function index()
        $items = Product::uses(['text', 'media', 'price','name'])
                //filter
                // ->compare('==', 'product.code', 'demo-selection-article-1')
                ->compare('==', 'product.siteid', '1.')
                //category
                ->category([7])
                //sorting
                ->sort('name')
                //limitation
                ->slice(0, 8)->search();
                // p($items);
         $items2 = Product::uses(['text', 'media', 'price','name'])
                //filter
                //category
                ->category([8])
                //sorting
                ->sort('name')
                //limitation
        $response['featured_products'] = parseProductData($items);
        $response['recommended_products'] = parseProductData($items2);
        // p($response);
        foreach( app( 'config' )->get( 'shop.page.mypage' ) as $name )
            $params['aiheader'][$name] = Shop::get( $name )->getHeader();
            $params['aibody'][$name] = Shop::get( $name )->getBody();
          // p($params);
        // return view('home')->with($params);
          return Response::view( 'home', array_merge($response,$params))->header( 'Cache-Control', 'no-store' );
        // $params = array();
        // foreach( app( 'config' )->get( 'shop.page.home' ) as $name )
        //    // $params['aiheader'][$name] = Shop::get( $name )->getHeader();
        //    // $params['aibody'][$name] = Shop::get( $name )->getBody();
        // return Response::view( 'home', $params )->header( 'Cache-Control', 'no-store' );
    public function customAction()
         p($params);
Post by aimeos » 27 Aug 2020, 09:27
The language/currency paramters passed in the URL are used. If there are none, the first locale combination in the Local panel is used.
