override save, get functions of Admin Product.
raghibkhesal2001
Post by raghibkhesal2001 » 20 Aug 2020, 15:23
I need to override save, get functions of Admin Product.
./ext/ai-admin-jqadm/admin/jqadm/src/Admin/JQAdm/Product/Standard.php
I created extension, but can anyone just provide me sample for this and guide me step by step please?
Re: override save, get functions of Admin Product.
Post by aimeos » 21 Aug 2020, 19:17
Here's a thread that could help you:
post6044.html#p6044
raghibkhesal2001
Post by raghibkhesal2001 » 24 Aug 2020, 09:07
As per the given guide, i created and copy "./ext/ai-admin-jqadm/admin/jqadm/src/Admin/JQAdm/Product/Standard.php" into "./ext/my-custom-ext/admin/jqadm/src/Admin/JQAdm/Product/ListStandard.php". Then changed the Class name into Liststandard.
Can you please just guide me what information should i require to add in configuration file (i am using laravel). So i can access custom extension -> product -> get function.
raghibkhesal2001
Post by raghibkhesal2001 » 24 Aug 2020, 13:45
Thanks for the guide and this work has been done.
Post by aimeos » 25 Aug 2020, 07:42
To your ./config/shop.php add:
'admin' => [
	'jqadm' => [
		'plugin' => [
			'name' => 'ListStandard'
to configure the name of your new class to be used instead of the Standard class.
