Add product to basket bug
cangpo
Post by cangpo » 06 Sep 2020, 07:54
Hello, product adding to basket does not work correctly.
For example, http://laravel.demo.aimeos.org/default/ ... -voucher/3 .
Im typing 100 into custom price, its add product to basket, typing 200 -- its added second product to 100 price!
Its also does not work with other attributes, its just does not rewrite it.
http://slim.demo.aimeos.org/default/en/ ... _article/0 -- here its work correctly, typing new custom price = add new product.
Help pls, how to fix it?
Re: Add product to basket bug
Post by aimeos » 08 Sep 2020, 12:15
Thank you for your bug report!
You are right, when adding vouchers with different prices, they are merged.
We will try to fix that and come back to you.
Post by aimeos » 09 Sep 2020, 16:34
The bug is fixed now in aimeos/aimeos-core dev-master and 2020.07.x-dev. It will be part of the next releases
