Url translation
dnll
Url translation
Post by dnll » 07 Sep 2020, 17:08
I'm a newby to Laravel and Aimeos and I'm using the default demo theme.
I've noticed that the urls are not accorded with the current language. I mean all the urls of the templates get the url to the default language which means that if I click on a product I'm redirected to detail page on the default language instead of the current language.
After some time I found the function url() and overrrided the templates, but it doesn't seem right that this feature is not set by default. Same thing with the search input. Am I missing something or overriding some feature without knowing? Can I override the url() function in to order to set this one time for all urls?
Thanks a lot for your help.
Re: Url translation
Post by aimeos » 08 Sep 2020, 15:18
Add a text of type "URL segment" for the languages you use and insert the name of the product in that language:
https://aimeos.org/docs/User_Manual/Adm ... ails#Texts
dnll
Re: Url translation
Post by dnll » 08 Sep 2020, 15:46
Thank you very much for this quick answer but it doesn't resolve the issue.
In bref, on the page 'http://localhost/shop?locale=fr&currency=EUR' all urls are set to the default language instead of french. For exemple 'http://localhost/shop?l_page=2' is missing the 'locale=fr&currency=EUR'.
Re: Url translation
Post by aimeos » 08 Sep 2020, 15:52
If you are using multiple locales (and/or currencies), then make sure you add the locale selector and set up routing correctly:
https://aimeos.org/docs/Laravel/Add_loc ... tor#Routes
dnll
Re: Url translation
Post by dnll » 08 Sep 2020, 16:43
Thank you very much !! It's works perfectly :D
