The selected attributes are not displayed in the catalog filter
Ahmad
Post by Ahmad » 12 Sep 2020, 14:01
i use aimeos/laravel 2020.07
The selected attributes are not displayed in the catalog filter, for example when i choose a color attribute in a category and then switch to another category that have not product with this color, list of available (selectable) color attributes not displayed and also selected attributes not show to deselect or clear all.
what can i do to show selected attributes?
Re: The selected attributes are not displayed in the catalog filter
Post by aimeos » 13 Sep 2020, 10:30
The checkbox for the attribute which isn't available is hidden by Javascript. If you want to show that, you can overwrite the JS code here: https://github.com/aimeos/ai-client-htm ... 1485-L1495
Post by aimeos » 13 Sep 2020, 11:19
There was a bug that prevented displaying the selected attributes. It's fixed in 2020.07.x-dev and you can install it using:
composer req aimeos/ai-client-html:2020.07.x-dev
