how to don't show home category in catalog/filter?
Ahmad
Post by Ahmad » 14 Sep 2020, 06:23
i use aimeos/laravel 2020.07
i want to show categories in catalog/filter from next level after home, because the home level is useless (users can click on logo or another button to go home page/cagetory.
i want to show categories like:
shoes
bags
shirts
instead of
home
    shoes
    bags
    shirts
what can i do for this?
Re: how to don't show home category in catalog/filter?
Post by aimeos » 14 Sep 2020, 07:51
Just hide the root category using CSS
parmonov98
Post by parmonov98 » 12 Oct 2020, 11:21
Ahmad wrote: 14 Sep 2020, 06:23 i use aimeos/laravel 2020.07
shoes
bags
shirts
instead of
home
    shoes
    bags
    shirts
YOU CAN DO LIKE THIS TO GET RID OF ROOT CATEGORY: https://imgur.com/nn7sQPa
Post by aimeos » 12 Oct 2020, 11:44
getName() is a really bad choice, you should use getCode() instead.
Alternatively, you can copy the tree-body.php template (https://github.com/aimeos/ai-client-htm ... rd.php#L75) and hand over the children directly:
'nodes' => [$this->treeCatalogTree->getChildren()],
parmonov98
Post by parmonov98 » 12 Oct 2020, 12:29
aimeos wrote: 12 Oct 2020, 11:44 getName() is a really bad choice, you should use getCode() instead.
if you meant the situation when I change the language, yeah! you're right. I didn't get to the language point. that was a quick solution for me.
How do you find other methods? (getCode())
let's rephrase the question: How can we find them list of methods?
Post by aimeos » 13 Oct 2020, 06:48
You can find all methods of the catalog items here:
https://github.com/aimeos/aimeos-core/b ... andard.php
