Prevent job from double execution
MikaelNazarenko
Expert
Post by MikaelNazarenko » 01 Oct 2020, 19:56
Good night, community !
Having a problem. I have created custom job as described here https://aimeos.org/docs/2020.x/cronjobs ... ontroller/
I tell me, please, do you know good solution, how to prevent my job from being executed several times simulationasly ?
For example I will add my job to cron which run each 1 minute. But what if started job has not finished yet ? I don't want this task to be executed, to say exactly - it may be executed, but need to detect that this task is running and prevent to perform the job...
Just realized, maybe it is not aimeos related question. So if I set cron like:
`* * * * * php /var/www/schmuck/artisan aimeos:jobs "order/email/delivery order/email/payment order/email/voucher order/service/delivery"`
how it works? Will it execute in 1 minutes if one of jobs is not finished ? - I just checked this, crontask keeps opening jobs...
Is it considered on standard aimeos jobs like
Aimeos components versions:
aimeos/ai-admin-jqadm                 2019.10.6  Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm               2019.10.2  Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html                 2019.10.10 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi              2019.10.2  Aimeos JSON API extension
aimeos/ai-controller-frontend         2019.10.3  Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs             2019.10.4  Aimeos ai-controller-jobs extension
aimeos/ai-gettext                     2019.10.1  Aimeos Gettext extension
aimeos/ai-laravel                     2019.10.2  Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments                    2019.10.1  Payment extension for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer                 2019.10.1  SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core                    2019.10.7  Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel                 2019.10.1  Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
Thanks!
Re: Prevent job from double execution
Post by aimeos » 03 Oct 2020, 07:37
You can create a shell script like this one:
#!/bin/bash
if [ ! -f aimeos.lock ]; then
	touch aimeos.lock
	rm aimeos.lock
fi
It tests if the "aimeos.lock" file exists and executes the jobs otherwise
