help in adapting/creating template
parmonov98
Post by parmonov98 » 07 Oct 2020, 04:01
to use a new template(HTML/CSS/js), I think I have to overwrite the layout structure of template.
if I change the structure completely, Do I need to rewrite every component?
Re: help in adapting/creating template
Post by aimeos » 07 Oct 2020, 16:55
You only need to overwrite the templates if you must change the HTML structure. Most often, it's not necessary because you can change most of the layout using CSS.
To overwrite templates, please have a look here:
https://aimeos.org/docs/latest/frontend ... templates/
If you only want to create a new theme, read these articles:
- https://aimeos.org/docs/latest/frontend ... me-basics/
- https://aimeos.org/docs/latest/frontend ... pt-themes/
