my custom theme is not working
parmonov98
Post by parmonov98 » 07 Oct 2020, 04:07
Can I change config to use a custom theme?
I have created an extenstion called elmobile. after that I tested components by copying some components from ai-client-html/../templates into elmobile/../template. I gave an inline styling that worked. but when I try to create custom theme is not getting applied. What can I do to fix?
https://imgur.com/e3swkqp
Re: my custom theme is not working
Post by aimeos » 07 Oct 2020, 16:58
You need to add your CSS/JS files to ./public/css/ or ./public/js/ and reference them in your copy of the base shop template:
https://github.com/aimeos/aimeos-larave ... .blade.php
