How can I change target?
parmonov98
Post by parmonov98 » 10 Oct 2020, 12:38
I use HomeController. /home route path and index method with name 'homepage'.
https://i.imgur.com/klZneUO.png
https://i.imgur.com/mfZmGnC.png
where is 'shop' coming from?
What is the 'client/html/catalog/tree/url/target'?
I wanna get target of homepage(home) for the l_type on page homepage.
how can I do?
Re: How can I change target?
Post by aimeos » 11 Oct 2020, 08:56
First of all, please read the article how to extend Laravel to create new pages:
https://aimeos.org/docs/latest/laravel/extend/
parmonov98 wrote: 10 Oct 2020, 12:38 https://i.imgur.com/mfZmGnC.png
The target is the Laravel route name configured here:
https://github.com/aimeos/aimeos-larave ... #L116-L275
parmonov98 wrote: 10 Oct 2020, 12:38 I wanna get target of homepage(home) for the l_type on page homepage.
how can I do?
The simplest way is to use the Laravel "route()" function to create a URL. If you want a more configurable solution that is compliant to the other Aimeos components, you can e.g. use "$this->link('client/html/homepage/url')" and configure "client/html/homepage/url/target" to the route name you have to add to your ./routes/web.php file.
BTW: In the new 2020.10 release there's already a "catalog-home" component which may fit your needs or you can adapt it to your requirements.
