how to add item to cart using ajax?
- parmonov98
I enabled basket-add in config. it works but I need customers to be able add items to cart without going to basket after click add to cart btn.
How can I do that? Once, I read about cline-jsonapi. is that what I need? if yes, please point me again!
https://imgur.com/CLxmcuM
Re: how to add item to cart using ajax?
You can use the JSON API but the easier solution is to use jQuery to display an overlay for the basket.
This is already implemented and works as long as you've not changed the CSS selectors:
https://github.com/aimeos/ai-client-htm ... 1279-L1290
- parmonov98
I'm not willing to use your css and other themes. I'm developing it with my own layouts/templates.
