deactivated products in sitemap
columbo
Post by columbo » 13 Oct 2020, 11:32
our aimoes sitemap xml contains all, also deactivated products.
Why are deactivated products also listed in the xml and how can we exclude those products?
thanks
Re: deactivated products in sitemap
Post by aimeos » 14 Oct 2020, 06:47
I remember there was a problem in the past that should have been fixed in latest 2019.10 and 2020.x
columbo
Post by columbo » 14 Oct 2020, 10:25
using Aimeos 2020.07
Sitemap xml is created daily, but as mentioned, contains also products that have been deactivated some months before
Post by aimeos » 14 Oct 2020, 12:23
Think, we've found the problem:
https://github.com/aimeos/ai-controller ... 99edd05f4c
Can you check if it works for you too?
columbo
Post by columbo » 14 Oct 2020, 18:18
yes, now its working fine - great
thanks!
