XML product import
XML product import
I've seen that the TYPO3 package of Aimeos has the ability of importing products from an XML file. As I didn't find anything in the documentation and the forums, I would like to know if the Laravel version has anything like that besides CSV and, if yes, is there is any guide about it, if not, will there be the possibility to do so in a future update?
Regards,
Martin
Regards,
Martin
Re: XML product import
The XML import is available for all platforms including Laravel but there's no documentation for that yet.
Attached are commented example files that can help you to create proper XML files for importing them into Aimeos.
- aimeos-xml.zip
- (9.39 KiB) Downloaded 438 times
