Trouble getting Omnipay Payment Expressworking
wing5wong
Post by wing5wong » 16 Oct 2020, 22:42
Hi there,
I just found this great shop package and im trying to integrate https://github.com/thephpleague/omnipay-paymentexpress as a payment gateway
This gateway redirects to its payment handling page to accept payments
i added options:
omnipay.type = PaymentExpress_PxPost or PaymentExpress_PxPay
omnipay.onsite = 0
omnipay.adress= 0
omnipay.createToken= 0
omnipay.authorize= 0
omnipay.password =
omnipay.username =
omnipay.pxPostPassword =
omnipay.pxPostUsername =
omnipay.testmode = 1
with PaymentExpress_PxPost i get error "The card parameter is required"
with PaymentExpress_PxPay i get the error "userid too short"
if i set omnipay.onsite =1 and use valid test card details i get an error with no text (just 1 bullet point)
Any idea at where i may be going wrong with getting this working?
Cheers,
Re: Trouble getting Omnipay Payment Expressworking
Post by aimeos » 17 Oct 2020, 09:22
Did you install the aimeos/ai-payments extension?
Also make sure you add the required parameters:
- PaymentExpress_PxPay: https://github.com/thephpleague/omnipay ... ateway.php
- PaymentExpress_PxPost: https://github.com/thephpleague/omnipay ... ateway.php
wing5wong
Post by wing5wong » 17 Oct 2020, 10:32
Hi there, sorry iu hadnt realised i was on an older version (2018.10)
I have just upgraded through to 2019.10 and the functionality seems to work as expected for PxPay (desired solution)
