Stripe no longer working
flomo
Post by flomo » 21 Oct 2020, 13:06
I just updated my shop from 2020.4 to 2020.10. Now the checkout no longer works with Stripe. After submitting the card number, I get the error "Call to undefined method Omnipay\Stripe\Message\Response::getPaymentIntentReference() ".
This may be similar to this issue: post11379.html
Currently installed versions:
aimeos/aimeos-laravel 2020.10.1
aimeos/aimeos-core 2020.10.5
aimeos/ai-payments 2020.10.1
omnipay/stripe v3.1.0
I was unable to find the method getPaymentIntentReference().
Re: Stripe no longer working
Post by aimeos » 22 Oct 2020, 11:07
Seems like there's still no new version released for Omnipay Stripe driver.
Can you use omnipay-stripe:dev-master?
flomo
Post by flomo » 22 Oct 2020, 14:17
I'm now on omnipay/stripe dev-master fbf57b3, but I still have the same issues. I even reset the config/shop.php file and removed my custom extension.
By the way, the same error was already thrown some months ago (see this post), so the issue might not be with omnipay/stripe.
Post by aimeos » 22 Oct 2020, 14:28
flomo wrote: 22 Oct 2020, 14:17 I'm now on omnipay/stripe dev-master fbf57b3, but I still have the same issues. I even reset the config/shop.php file and removed my custom extension.
The code is the same in 2020.10 and this was not related to getPaymentIntentReference():
https://github.com/aimeos/ai-client-htm ... hp#L69-L81
What is the exact error message and the stack trace when the error occurs?
flomo
Post by flomo » 22 Oct 2020, 14:45
Exactly. But back then I also got the same error message, when paying with Stripe. In contrast to the error back then, however, the response from Stripe looks ok this time.
https://flareapp.io/share/DPyLrWRm
Post by aimeos » 23 Oct 2020, 16:02
Can you share the output of "composer show" for the installation that throws the error?
flomo
Post by flomo » 24 Oct 2020, 09:16
Here's the installed components:
academe/omnipay-datatrans 3.0.5 Datatrans Gateway for the Omnipay payment processing library
aimeos/ai-admin-jqadm 2020.10.2 Aimeos Vue.js+Bootstrap admin interface
aimeos/ai-admin-jsonadm 2020.10.1 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html 2020.10.5 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi 2020.10.2 Aimeos JSON API extension
aimeos/ai-controller-frontend 2020.10.1 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs 2020.10.2 Aimeos ai-controller-jobs extension
aimeos/ai-gettext 2020.10.1 Aimeos Gettext extension
aimeos/ai-laravel 2020.10.2 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments 2020.10.1 Payment extension for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer 2020.10.1 SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core 2020.10.5 Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel 2020.10.1 Professional, full-featured and high performance Laravel e-commerce package for online shops and compl...
aimeos/map 1.8.0 Easy and elegant handling of PHP arrays as array-like map objects similar to jQuery and Laravel Collec...
asm89/stack-cors 1.3.0 Cross-origin resource sharing library and stack middleware
brick/math 0.9.1 Arbitrary-precision arithmetic library
clue/stream-filter v1.5.0 A simple and modern approach to stream filtering in PHP
composer/installers v1.9.0 A multi-framework Composer library installer
deployer/deployer v6.8.0 Deployment Tool
deployer/phar-update v2.2.0 Integrates Phar Update to Symfony Console.
dnoegel/php-xdg-base-dir v0.1.1 implementation of xdg base directory specification for php
doctrine/cache 1.10.2 PHP Doctrine Cache library is a popular cache implementation that supports many different drivers such...
doctrine/dbal 2.11.3 Powerful PHP database abstraction layer (DBAL) with many features for database schema introspection an...
doctrine/event-manager 1.1.1 The Doctrine Event Manager is a simple PHP event system that was built to be used with the various Doc...
doctrine/inflector 2.0.3 PHP Doctrine Inflector is a small library that can perform string manipulations with regard to upper/l...
doctrine/instantiator 1.3.1 A small, lightweight utility to instantiate objects in PHP without invoking their constructors
doctrine/lexer 1.2.1 PHP Doctrine Lexer parser library that can be used in Top-Down, Recursive Descent Parsers.
dompdf/dompdf v0.8.6 DOMPDF is a CSS 2.1 compliant HTML to PDF converter
dragonmantank/cron-expression v3.0.2 CRON for PHP: Calculate the next or previous run date and determine if a CRON expression is due
egulias/email-validator 2.1.22 A library for validating emails against several RFCs
facade/flare-client-php 1.3.6 Send PHP errors to Flare
facade/ignition 2.4.1 A beautiful error page for Laravel applications.
facade/ignition-contracts 1.0.2 Solution contracts for Ignition
fideloper/proxy 4.4.0 Set trusted proxies for Laravel
filp/whoops 2.9.0 php error handling for cool kids
florianmoser/plesk-deployer v6.2.0 Deployer common recipe fixes to deploy on shared hostings using Plesk
fruitcake/laravel-cors v1.0.6 Adds CORS (Cross-Origin Resource Sharing) headers support in your Laravel application
fzaninotto/faker v1.9.1 Faker is a PHP library that generates fake data for you.
graham-campbell/result-type v1.0.1 An Implementation Of The Result Type
guzzlehttp/guzzle 6.5.5 Guzzle is a PHP HTTP client library
guzzlehttp/promises 1.4.0 Guzzle promises library
guzzlehttp/psr7 1.7.0 PSR-7 message implementation that also provides common utility methods
hamcrest/hamcrest-php v2.0.1 This is the PHP port of Hamcrest Matchers
laminas/laminas-diactoros 2.4.1 PSR HTTP Message implementations
laminas/laminas-zendframework-bridge 1.1.1 Alias legacy ZF class names to Laminas Project equivalents.
laravel/framework v8.11.2 The Laravel Framework.
laravel/telescope v4.2.0 An elegant debug assistant for the Laravel framework.
laravel/tinker v2.4.2 Powerful REPL for the Laravel framework.
laravel/ui v3.0.0 Laravel UI utilities and presets.
league/commonmark 1.5.6 Highly-extensible PHP Markdown parser which fully supports the CommonMark spec and Github-Flavored Mar...
league/flysystem 1.1.3 Filesystem abstraction: Many filesystems, one API.
league/mime-type-detection 1.5.1 Mime-type detection for Flysystem
mockery/mockery 1.4.2 Mockery is a simple yet flexible PHP mock object framework
moneyphp/money v3.3.1 PHP implementation of Fowler's Money pattern
monolog/monolog 2.1.1 Sends your logs to files, sockets, inboxes, databases and various web services
myclabs/deep-copy 1.10.1 Create deep copies (clones) of your objects
nesbot/carbon 2.41.3 An API extension for DateTime that supports 281 different languages.
nikic/php-parser v4.10.2 A PHP parser written in PHP
nunomaduro/collision v5.0.2 Cli error handling for console/command-line PHP applications.
nyholm/psr7 1.3.1 A fast PHP7 implementation of PSR-7
omnipay/common v3.0.4 Common components for Omnipay payment processing library
omnipay/stripe dev-master fbf57b3 Stripe driver for the Omnipay payment processing library
opis/closure 3.6.0 A library that can be used to serialize closures (anonymous functions) and arbitrary objects.
paragonie/random_compat v9.99.100 PHP 5.x polyfill for random_bytes() and random_int() from PHP 7
phar-io/manifest 2.0.1 Component for reading phar.io manifest information from a PHP Archive (PHAR)
phar-io/version 3.0.2 Library for handling version information and constraints
phenx/php-font-lib 0.5.2 A library to read, parse, export and make subsets of different types of font files.
phenx/php-svg-lib v0.3.3 A library to read, parse and export to PDF SVG files.
php-http/discovery 1.12.0 Finds installed HTTPlug implementations and PSR-7 message factories
php-http/guzzle6-adapter v1.1.1 Guzzle 6 HTTP Adapter
php-http/httplug v1.1.0 HTTPlug, the HTTP client abstraction for PHP
php-http/message 1.9.1 HTTP Message related tools
php-http/message-factory v1.0.2 Factory interfaces for PSR-7 HTTP Message
php-http/promise 1.1.0 Promise used for asynchronous HTTP requests
phpdocumentor/reflection-common 2.2.0 Common reflection classes used by phpdocumentor to reflect the code structure
phpdocumentor/reflection-docblock 5.2.2 With this component, a library can provide support for annotations via DocBlocks or otherwise retrieve...
phpdocumentor/type-resolver 1.4.0 A PSR-5 based resolver of Class names, Types and Structural Element Names
phpoption/phpoption 1.7.5 Option Type for PHP
phpspec/prophecy 1.12.1 Highly opinionated mocking framework for PHP 5.3+
phpunit/php-code-coverage 9.2.0 Library that provides collection, processing, and rendering functionality for PHP code coverage inform...
phpunit/php-file-iterator 3.0.5 FilterIterator implementation that filters files based on a list of suffixes.
phpunit/php-invoker 3.1.1 Invoke callables with a timeout
phpunit/php-text-template 2.0.3 Simple template engine.
phpunit/php-timer 5.0.2 Utility class for timing
phpunit/phpunit 9.4.2 The PHP Unit Testing framework.
pimple/pimple v3.3.0 Pimple, a simple Dependency Injection Container
psr/container 1.0.0 Common Container Interface (PHP FIG PSR-11)
psr/event-dispatcher 1.0.0 Standard interfaces for event handling.
psr/http-factory 1.0.1 Common interfaces for PSR-7 HTTP message factories
psr/http-message 1.0.1 Common interface for HTTP messages
psr/log 1.1.3 Common interface for logging libraries
psr/simple-cache 1.0.1 Common interfaces for simple caching
psy/psysh v0.10.4 An interactive shell for modern PHP.
ralouphie/getallheaders 3.0.3 A polyfill for getallheaders.
ramsey/collection 1.1.1 A PHP 7.2+ library for representing and manipulating collections.
ramsey/uuid 4.1.1 A PHP library for generating and working with universally unique identifiers (UUIDs).
sabberworm/php-css-parser 8.3.1 Parser for CSS Files written in PHP
scrivo/highlight.php v9.18.1.3 Server side syntax highlighter that supports 185 languages. It's a PHP port of highlight.js
sebastian/cli-parser 1.0.1 Library for parsing CLI options
sebastian/code-unit 1.0.7 Collection of value objects that represent the PHP code units
sebastian/code-unit-reverse-lookup 2.0.3 Looks up which function or method a line of code belongs to
sebastian/comparator 4.0.5 Provides the functionality to compare PHP values for equality
sebastian/complexity 2.0.1 Library for calculating the complexity of PHP code units
sebastian/diff 4.0.3 Diff implementation
sebastian/environment 5.1.3 Provides functionality to handle HHVM/PHP environments
sebastian/exporter 4.0.3 Provides the functionality to export PHP variables for visualization
sebastian/global-state 5.0.1 Snapshotting of global state
sebastian/lines-of-code 1.0.1 Library for counting the lines of code in PHP source code
sebastian/object-enumerator 4.0.3 Traverses array structures and object graphs to enumerate all referenced objects
sebastian/object-reflector 2.0.3 Allows reflection of object attributes, including inherited and non-public ones
sebastian/recursion-context 4.0.3 Provides functionality to recursively process PHP variables
sebastian/resource-operations 3.0.3 Provides a list of PHP built-in functions that operate on resources
sebastian/type 2.3.0 Collection of value objects that represent the types of the PHP type system
sebastian/version 3.0.2 Library that helps with managing the version number of Git-hosted PHP projects
swiftmailer/swiftmailer v6.2.3 Swiftmailer, free feature-rich PHP mailer
symfony/console v5.1.7 Symfony Console Component
symfony/css-selector v5.1.7 Symfony CssSelector Component
symfony/deprecation-contracts v2.2.0 A generic function and convention to trigger deprecation notices
symfony/error-handler v5.1.7 Symfony ErrorHandler Component
symfony/event-dispatcher v5.1.7 Symfony EventDispatcher Component
symfony/event-dispatcher-contracts v2.2.0 Generic abstractions related to dispatching event
symfony/finder v5.1.7 Symfony Finder Component
symfony/http-client-contracts v2.3.1 Generic abstractions related to HTTP clients
symfony/http-foundation v5.1.7 Symfony HttpFoundation Component
symfony/http-kernel v5.1.7 Symfony HttpKernel Component
symfony/mime v5.1.7 A library to manipulate MIME messages
symfony/polyfill-ctype v1.18.1 Symfony polyfill for ctype functions
symfony/polyfill-iconv v1.18.1 Symfony polyfill for the Iconv extension
symfony/polyfill-intl-grapheme v1.18.1 Symfony polyfill for intl's grapheme_* functions
symfony/polyfill-intl-idn v1.18.1 Symfony polyfill for intl's idn_to_ascii and idn_to_utf8 functions
symfony/polyfill-intl-normalizer v1.18.1 Symfony polyfill for intl's Normalizer class and related functions
symfony/polyfill-mbstring v1.18.1 Symfony polyfill for the Mbstring extension
symfony/polyfill-php70 v1.18.1 Symfony polyfill backporting some PHP 7.0+ features to lower PHP versions
symfony/polyfill-php72 v1.18.1 Symfony polyfill backporting some PHP 7.2+ features to lower PHP versions
symfony/polyfill-php73 v1.18.1 Symfony polyfill backporting some PHP 7.3+ features to lower PHP versions
symfony/polyfill-php80 v1.18.1 Symfony polyfill backporting some PHP 8.0+ features to lower PHP versions
symfony/process v5.1.7 Symfony Process Component
symfony/psr-http-message-bridge v2.0.2 PSR HTTP message bridge
symfony/routing v5.1.7 Symfony Routing Component
symfony/service-contracts v2.2.0 Generic abstractions related to writing services
symfony/string v5.1.7 Symfony String component
symfony/translation v5.1.7 Symfony Translation Component
symfony/translation-contracts v2.3.0 Generic abstractions related to translation
symfony/var-dumper v5.1.7 Symfony mechanism for exploring and dumping PHP variables
symfony/yaml v5.1.7 Symfony Yaml Component
tecnickcom/tcpdf 6.3.5 TCPDF is a PHP class for generating PDF documents and barcodes.
theseer/tokenizer 1.2.0 A small library for converting tokenized PHP source code into XML and potentially other formats
tijsverkoyen/css-to-inline-styles 2.2.3 CssToInlineStyles is a class that enables you to convert HTML-pages/files into HTML-pages/files with i...
vlucas/phpdotenv v5.2.0 Loads environment variables from `.env` to `getenv()`, `$_ENV` and `$_SERVER` automagically.
voku/portable-ascii 1.5.3 Portable ASCII library - performance optimized (ascii) string functions for php.
webmozart/assert 1.9.1 Assertions to validate method input/output with nice error messages.
Post by aimeos » 26 Oct 2020, 11:47
Can you please try this fork?
https://github.com/aimeoscom/ai-payments
If it works, we have to see what has changed in the Omnipay Stripe driver.
flomo
Post by flomo » 26 Oct 2020, 19:49
Not sure which fork you mean. Your link points to the official aimeos/ai-payments package, which I have already installed.
I switched to dev-master for aimeos/aimeos-laravel and aimeos/ai-payments, but that didn't help. Still the same error.
Post by aimeos » 27 Oct 2020, 07:26
Sorry, this is the correct link:
https://github.com/aimeoscom/omnipay-stripe
